![]() | Home > Off Topic > rave on android |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880
got meself an android tablet and was wondering if rave could be put on it..would be dead handy when actually doing something on the range and having the tablet/rave to refer to.. ... - .- -.
thought of that already but it seems the rave pdf's are encrypted? and wont open... ... - .- -.
| ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 |
Seems odd. They open fine on my Linux machine using the standard pdf viewer. Will put one on my android phone tonight and see. If it doesn't work and is really encrypted then since I have a machine that can actually read it I can soon re-encode it for you if needed. |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6838
Foxed if I know! |
Tested fine on my android phone using the Adobe PDF viewer. |
cheers ric, must be the foxit reader.. |
Yip, tis foxed! Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
ok, tried to open the pdf files which i transferred from my laptop onto my android tablet but they still wont open ..using the adobe pdf reader ..any ideas? ... - .- -.
Do you get any error messages? Perhaps they have somehow been corrupted during the transfer? What method did you use to transfer them over? Try transferring them back (don't overwrite the originals!) and see if they will open on your laptop again. I'm using v10.0.2 build 40862 of Adobe PDF on my phone, which has Android v2.3.4 |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
Stan - what you want is google Docs - upload the PDF's there, install google docs onto ur device and browse away |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Well I can't read the rave pdfs outside of the rave cd either (ie without using the built-in reader) unless someone can provide (via pm of course!) the password on the pdf security? .
Perhaps I have a different version of rave. There is no reader with mine, but then I'm using it on Linux anyway. I'm just navigating into the right folder and opening the pdf files directly. I downloaded it from the web, but to be honest I can't remember where. I must have got the link off here though. |
| Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673
The RAVE I have has its own Acrobat Reader (v4?) with a special plugin to read the encrypted PDFs. They won't work with any other version. |
| All times are GMT |
