Home > Maintenance & Mods (L322) > Howto: TD6 Transfer Box Oil Change
New photo tutorial on changing the oil on your TD6 transfer box Very Happy
http://www.fullfatrr.com/gallery/thumbnails.php?album=343
N.B. If pictures are not in number order, click on Title and Sort Ascending .
Post #83679 25th Sep 2011 1:19am
What was the oil you removed like Joe, mine was way beyond its sell by date
Post #83686 25th Sep 2011 8:49am
A bit thin, very black, not too gritty and no swarf. I had a new gearbox @ 30,000 miles ago, and don't know if this oil got changed then, but given the difference between the old and the new oil, I was glad I changed it. .
Post #83689 25th Sep 2011 9:20am
On a note would it be worth having the car on an incilne to help drain more of the old bad fluid out and then if possible allowing the car to roll back onto flat ground to fill up??
I guess we are only talking about maybe another 10-20mls maybe more but is it not better to get as much bad stuff out as possible or does it only take about 400ml to fill so you cna do another change not long after?
Post #83693 25th Sep 2011 9:48am
i've taken the liberty to wiki this joe....good job as always. Thumbs Up ... - .- -.
Post #83705 25th Sep 2011 11:17am
DaveAngel
2015 Range Rover Vogue SE SDV8 Barolo Black
Great post Joe,
Can I ask how much you spent on oil and filter though? when i costed it up worked out about a tenner difference to get a specialist to do it. __________________
2015 FFRR SDV8
2011 FFRR TDV8 4.4 - Gone
2005 FFRR TDV6 - Gone
Post #83723 25th Sep 2011 12:49pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
After you did the oil change did you operate the hi / lo range selecter as the bit of kit in the box that changes from hi / lo requires hyd oil to change selection if not when you operate it it will suck oil up to fill the pump and leave your level in the box low please check level after operating the hi / lo selection Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #83738 25th Sep 2011 4:01pm
DaveAngel wrote:
Great post Joe,
This is the transfer case (box) oil change, not the main gearbox, so just a 1 litre bottle of "unique" oil for @ £12, and about half an hours work. .
Post #83739 25th Sep 2011 4:19pm
I would have done the hi/lo change about, but this is the part of my transmission that doesn't work!. If I put into low range I get the TFP message on the dash, and the Censored won't come out of low range, so I have to fit a dismantled shift motor and wind it back to high range by hand. This is a PITA, it's going to an Indie for fault codes.
Wasn't aware the hi/lo shift required the oil other than for lubrication, if you check out RRPhil's video on a cutaway gearbox, it seems it is a very straightforward mechanical movement. I saw your other post about this and was a little unsure about the hydraulic requirements? .
Post #83740 25th Sep 2011 4:25pm
