Home > Technical (L322) > squeaky belt noise on startup
barrieeld
anyone know what a squeaky belt noise on cold startup would be? and should i get it looked at to replace?
Post #84010 26th Sep 2011 9:23pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
My SC suffered from a squeak on startup, which was rectified under warranty by replacing the main drive belt pulley.
Accoding to my dealer, its a know issue on the SC, but I've no idea if its a problem on other engines.
Gone - Range Rover Supercharged 2006
Post #84015 26th Sep 2011 9:34pm
Are you sure its the belt and not the tensioner?
Post #84018 26th Sep 2011 9:39pm
what range have you got barrieeld, you need to update your car profile.. Thumbs Up ... - .- -.
Post #84019 26th Sep 2011 9:40pm
barrieeld
Hi I've got a supercharged if that helps. My cars a 2006 so it'll be out of warranty.
Anyone know what costs are involved? And what will been replaced?
Am I right and thinking the jag units have tensioners an the noise could be the 2 belts for alternator etc
Post #84021 26th Sep 2011 9:51pm
JustinP
FYI my SC is also a 2006, the warranty is the approved used warrenty that comes with a main dealer supplied car.
The job took 1.8 hours and required the following parts
PQR500350 -pulley
JYP000040 - screw
PQM500030 - bolt
PQR500320 - Belt
It's one of the few warranty jobs that I have the paperwork for.
Post #84029 26th Sep 2011 10:02pm
barrieeld
PQR500350 -pulley
JYP000040 - screw
PQM500030 - bolt
PQR500320 - Belt
Hi I bought my vehicle privately although it's been looked after from a maim dealer from new it won't have any warranty I don't think?
Any idea the cost of the parts?
Post #84033 26th Sep 2011 10:14pm
Its a common issue but the squeak normally disappears after warm up. Not sure if leaving it will lead to mechanical failure?
Post #84034 26th Sep 2011 10:16pm
barrieeld
Yeh that's right after warmup the engine squeak disappears.
Post #84036 26th Sep 2011 10:19pm
JustinP
The paperwork shows less than £50 all in for the parts, but that may be discounted as the LR warranty picked up the bill.
Post #84045 26th Sep 2011 10:27pm
SharpV8
Had exactly the same problem on my 2006 SC, although in my case they diagnosed a faulty belt which was replaced (not under the LR warranty sadly)... I thought it would be the pulley and was sceptical a new belt would fix it, but the noise has certainly gone - along with a clutch of notes from my wallet Laughing Range Rover TDV8 Vogue SE
Post #84523 29th Sep 2011 7:46am
