![]() | Home > General > How tall is the FFRR? |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 884 ![]() ![]() ![]() |
Range Rover's height is 1903mm, access height is 1863mm.
inkiboo Member Since: 13 Nov 2009 Location: Aubonne Posts: 80 ![]() ![]() ![]() |
Brilliant, thank you. |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1123 ![]() ![]() |
On the same subject even on its lowest setting the figures say you can not travell on the double deck Eurotunel, but you can, I have done it several times, both up top and down under. letters not necessarily in the right order |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
I have been told that the rear GPS aerial on facelift models can get whacked, its not worth the risk, costs no more so may as well go in the overheight carriage, less crowded too. Discovery 4 HSE
Mine is a face lift and there was a good 6 inches clear. The others are not as frequent and when the fire hit last year they did not run at all. letters not necessarily in the right order |
ukrangie Member Since: 20 Jun 2009 Location: Kent Posts: 520 ![]() ![]() ![]() |
it's still daunting driving through car parks such as Jubilee Place at Canary Wharf where the height clearance is a little over 2m |
I'm not allowed on the channel tunnel - LPG = bad apparently. Although you can take your campervan full of LPG bottles. Go figure. |
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 ![]() ![]() |
I think the answer to the initial question is ...... "too tall to wash without using a step ladder" |
