Home > Maintenance & Mods (L322) > tv screen upgrade
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
tv screen upgrade
hi
i have a normal tv /nav screen in my ffrr can it be upgraded to the touch screen
also does anyone have link to upgrade my nav maps i have the mk3 cd nav unit
many thanks
Post #85270 4th Oct 2011 4:28pm
no you cant upgrade from non to touch screen as the wiring is completely different, and links to non copyrighted downloads are not allowed.. ... - .- -.
Post #85272 4th Oct 2011 4:31pm
Fr_Raf
France 2004 Range Rover Vogue 4.4 V8 Java Black
Bow down
But it is possible to upgrade with an MK4 system he can bought for exemple on the bay
Post #85274 4th Oct 2011 4:50pm
dannyp15
thats a shame Big Cry
need to do the nav mk4 upgrade soon as the old mk3 is 2bob looks like a spectrum 48k graphics
Post #85277 4th Oct 2011 5:02pm
the mk3 system is easily upgraded to the mk4 dvd based jobby and the dvd mapping disc might be in with the price ...if the dvd is not included , the map software 'can' be downloaded.. Wink ... - .- -.
Post #85278 4th Oct 2011 5:07pm
dannyp15
nice 1 put it on the list of things to do the the beast
Post #85279 4th Oct 2011 5:09pm
there are also after market style options IIRC that run on windows ce and android i think one ran on with everything built in like DVB-T and so forth.
Post #85291 4th Oct 2011 5:37pm
the problem with the winCE based ones is that they are so clunky, even more so than the FFRR one ,but if you can put up with that they're a good alternative..the future must be the internet based units .. ... - .- -.
Post #85295 4th Oct 2011 5:46pm
Im sure the android ones should be half decent, i mean they can put a decent processor and ram in them so they shouldn't be too bad.
IIRC someone on here has one fitted and thinks its quite good, maybe go and see it and see how it feels.
Post #85304 4th Oct 2011 6:08pm
re android ,here's a link to blog which is pretty interesting..
http://blog.androidcaraudio.com/ ... - .- -.
Post #85309 4th Oct 2011 6:19pm
SteveMFr
Site Sponsor
For those with the CD-Radio OEM the aftermarket satnav is a good alternative. Ripping out an OEM nav to replace it with an aftermarket unit is a silly thought.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #85317 4th Oct 2011 7:19pm
daveo
dannyp, one thing to keep in mind is that the head unit you have is not capable of displaying a great picture, the touch screens almost doubled in resolution, the nav upgrade does run better but the price for the mk4 units are high. you can go for a car pc that involves changing the screen to a aftermarket touch screen but fitting it in to your factory unit. you will be looking at changing the tv module for a digital free view unit.. V8 facelift Range Rover Autobiography 22" wheels.
Post #85334 4th Oct 2011 9:22pm
dannyp15
I like that android bit of kit that's the sort of thing I want not worried about ripping the old RR system. Out which is crap in my book and to out of date
Post #85384 5th Oct 2011 8:14am
SteveMFr
Site Sponsor
Nice to know you've got a modern book. Rolling with laughter
Yes, the system is no longer cutting edge and yes the monitor's resolution could be better and yes, the twisty push-knob is a bit of a PITA to use. Updated with a MKIV the system works really well tho. And with judicious use of BMW bits you can add bluetooth, voice recognition, iPod/MP3, reverse camera, and all sorts of other neato peteato additions. And you'll have a system that really works well and is integrated into the car like no other aftermarket system - unless you're willing to put the amount of work and time in that Matt Stevenson did (or is - don't know that he's finished yet). Search under his UN - there's more info if you're interested in building a custom carPC. I elected to go a less time consuming route so that I would be guaranteed to finish (I've got my share of unfinished projects floating around...). I have a touch screen overly on my monitor and switch to my carPC via the mode button. Daveo's system is similar only with a BMW system emulator so that he can use the twisty push-knob to interface with the system.
Without going to a carPC - or even if - I'd still consider the following:
Satnav:
parts needed: MKIV (DVD) drive & latest FW. Plenty of info and Mattstevenson even has modified FW avail for download for free on his site
iPod/iPhone:
parts needed: intravee + Alpine KCA 420i - http://intravention.co.uk/
You can do similar with other units for less (Dice, Grom)- but this is the best. If you do a carPC you can skip this bit
Bluetooth:
parts needed: BMW ULF and poss phone harness if not already fitted (pins in plug need to be changed).
Bluetooth, contacts, text messaging - all on the oem displays
And voice recognition
cheaper alternative avail from Dension with less features
I'd def go with the OEM bluetooth unless you want to do something like Matt Stevenson - he's reading commands from the i-bus so that the vehicle controls will interface with his PC and he'll have OEM level integration (steering wheel controls, voice recognition, etc).
Without a lot of effort, you will not be making the system better - guaranteed.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #85493 5th Oct 2011 7:15pm
SteveMFr
Site Sponsor
Dave, we've been through this before. I know you've got the PC hooked to your nav and a windows desktop look like ship - but you're going through a VGA-TV converter too.
On native resolution the pic is quite good - and TBH unless you're extremely farsighted or watch TV at 4 inches it really is ok. And you can't read a windows desktop from the driver's seat in a 2012 RR either.
You can click on the little bird and check the details in the pic... Thought this was ok as an example this afternoon. Yes, you can make it better, but the ROI is not worth it IMO. A dual view screen, tho... Cool
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #85498 5th Oct 2011 7:45pm
