Home > Technical (L322) > Help Needed...Multiple Warning Lights |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
Failure of the Bosch ABS ECU is fairly common on the E39 5 series BMW, with which the FFRR shares a lot of components.
4th Oct 2011 10:08pm |
On the BMW, it is a broken/loose connection inside the ECU case, the ECU sees this as what it is, an open circuit in an ABS sensor connection, however it is INSIDE the case, not the sensor itself or the wiring to it. |
6th Oct 2011 8:49pm |
mrbon007 Member Since: 19 Apr 2011 Location: London Posts: 11 |
Thanks that makes a lot of sense, will try to get it looked at in more depth. |
6th Oct 2011 9:40pm |
Ok i have decided to take the plunge and replace the only remaining component in the system - the ABS pump & control module.
11th Oct 2011 11:05pm |
Why not send it to BBA Reman and see if they can repair it |
11th Oct 2011 11:24pm |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 219 |
If the battery is anything approaching five years old, you will need a new one. No ifs, no buts. Without research, it will be £120 or so, maybe less. Do this first.
12th Oct 2011 12:22am |
finlander Member Since: 12 Oct 2011 Location: bradwell on sea Posts: 4 |
Ok, heres my view...
12th Oct 2011 2:36am |
Sammyg1413 Member Since: 02 Oct 2011 Location: North west Posts: 16 |
Sorry to buzz in. This problem sounds same as mine which I recently posted.
12th Oct 2011 10:27am |
The battery is charged to 101% (?!) and the alternator tests show thats fine too...
20th Oct 2011 6:06pm |
did you test the alternator whilst the lights were all on to see if the charge to the batt had dropped?
20th Oct 2011 6:40pm |
23rd Oct 2011 3:32pm |
mmm... yes very well...
29th Oct 2011 3:13pm |
