Home > General > Suspension Query Part 2
barrieeld
Was driving today when all of a sudden I got "suspension fault" coming up on the dash....I looked at the the suspension dial and the lights were off?
I stopped the car and restarted and its been fine since....any ideas?
Post #85353 4th Oct 2011 10:32pm
Re: Suspension Query Part 2
barrieeld wrote:
....any ideas?
One of the many joys of owning a FFRR Big Cry
Post #85355 4th Oct 2011 10:33pm
barrieeld
is the suspension f*****d? of just one of these technical gremlins?
If it is then what cost r we talking about?
Post #85358 4th Oct 2011 10:38pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Mine has done it before as well.......... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #85360 4th Oct 2011 10:40pm
If you stopped and restarted with no faults it looks like it could have been a glitch. Best just keep an eye on it and hope for the best, or as an ex manager of mine used to say....."Let it develop" Big Cry
Post #85361 4th Oct 2011 10:40pm
rayc
United Kingdom 2007 Range Rover Vogue SE TDV8 Rimini Red
Possible the compressor wasn't able to keep up with demand.
My mate had a similar issue which was caused by the sensor getting "confused".
He parked on level ground, took battery off for half an hour. Reset the steering sensor and it's been fine since. 08 model TDV8 Vogue SE Rimini Red/ parchment. 04 TD6 Vogue Oslo Blue / parchment
99 Model 2.5 DSE Rioja Red / lightstone
97 BMW M3 Evo Convertible
plus a few more!
Post #85363 4th Oct 2011 10:42pm
barrieeld
Every time i stop the vehicle i always put the car into access mode as i like the suspension to keep flexing is this the correct method to keep the suspension active?
Post #85365 4th Oct 2011 10:52pm
Some believe so, I personally don't bother
Post #85366 4th Oct 2011 10:53pm
CG-SC
Well I can hear the compressor when it runs due to the LPG relocation (not too loud, but audible) When you are aware how long it runs for and how hard the thing works you wouldn't put it into access mode every time you stop it !!
I leave mine in normal mode - occassionally I drop it and raise it but certainly not every time..... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #85368 4th Oct 2011 11:04pm
barrieeld
True but then the other argument is leaving the vehicle in normal mode puts unwanted stress on the vehicle having to continually monitor the pressure while left parked overnight say?
Post #85373 4th Oct 2011 11:36pm
ric355
This is moot - if there are no leaks then nothing will happen. There is no "stress" in monitoring the height of the vehicle when it isn't changing. Conversely if it does change height then you have a leak and therefore already have something that needs fixing! I don't get the stress issue anyway - there's still air in the bags whether it is in access mode or normal mode. Just less of it in access mode but it's still holding up the weight of the body; it is not resting on the bump stops.
Obviously the more times you lower and raise the more wear there will be on the compressor. But using it isn't a bad thing - that's what it's for after all.
Just park it up and don't worry about it. The only reason to always put it in access mode would be if the owners handbook tells you. And I doubt it does.
Post #85376 4th Oct 2011 11:47pm
Why oh why did I read this thread earlier today.
Popped down to the bank this afternoon - Air Susp Inactive message popped up, lights all off on the console. Ding when I switched off. Seems to have dropped a bit front drivers side. Switching car back on continues to give fault and no lights. So I now have a thrilling journey home at a careful speed Wink
So next steps? What is the likely problem? Have checked fuse 57 (15 amp) this is OK. .
Post #85447 5th Oct 2011 3:49pm
joe, if you have time ,put "air suspension inactive" with the quotation marks into the search and there is tons of info re this...i had a quick read but didn't get a definitive answer, mind you a only read a few threads.. ... - .- -.
Post #85453 5th Oct 2011 3:57pm
Try disconnecting the battery for half an hour, though if it does re-set it will most likely pop up a fault as soon as you drive again.
It can be a Censored load of things that trigger the fault and not always Air Suspension orientated either. ABS, speed sensor, steering angle sensor, compressor overheat, relief valve on air tank.....the list goes on
Post #85457 5th Oct 2011 4:02pm
@ scarey - that's what I've just been doing since I posted, just thought I would report the synchronicity of reading about the ASI problem and it then happening to me Big Cry Laughing
@47p2 - thanks for the suggestions, I'll try a few low tech fixes before running it over to my Indie. Most folks seemed to have had a split air bag on the drivers side. I don't seem to be on the bump stops though (although I have only ever felt what this is like in my P38 when the whole lot dropped on me one day Wink)
Just been out and prodded the airbags - OSR front soft - low height, NSL front hard - normal height, rear ones all OK, so looking like a dodgy air bag? .
Post #85467 5th Oct 2011 4:20pm
