Home > Technical (L322) > Couple of Questions
barrieeld
Couple of Questions
Probably been done before but i wanted to double check...
1) Has anyone managed to get their contacts list, SMS data etc to appear on the nav screen via bluetooth? Is this functionality only available via a docking cradle? If so i take it there is no solution for iPhone 4 on this?
My car is a 2006 FFSC
2) Is there any way to anster calls from the steering wheel rather than having to press the nav screen?
Post #85551 6th Oct 2011 11:22am
barrieeld
nobody?
Post #85905 7th Oct 2011 9:28pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
What phone is it? it has to be compatible. A forum member named Wiggs can sell you an updated bluetooth module which will be compatible with most contemporary phones, such as iPhone. For me it was a waste of time because you can still only transfer 300 contacts, which meant it was a little random as to which of mine transferred. Otherwise it's a great fix for not much money.
Do a search on bluetooth module and you'll find plenty of info! 2012 SDV8 Vogue SE
Post #85935 7th Oct 2011 11:03pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I got (from a very generous) forum member 'the doc' a 2007 BT module and I've had a 3GS and two simultaneous IP4s (home and work) and they all worked flawlessly.
Though as per the previous I'm med to believe if you ask Wiggs ideally for a 2010 module this is the best overall.
Good luck! Thumbs Up
Post #85945 8th Oct 2011 12:07am
barrieeld
Great guys I'll check it out... Know a rough price?
Also foe answering calls is pressing the nav unit the only way?
Post #85956 8th Oct 2011 8:06am
Stephen.125
Think the 2010 unit is around £120-130 though I suppose it may depend on availability. The other as an exchange unit was about half; Though again could have gone up.
You can press the voice control button on the steering wheel to answer and end calls. Not sure if it matters which mode you are in (radio/tel button is next to it anyhow)
Post #85961 8th Oct 2011 9:06am
barrieeld
For some reason my steering wheel doesn't have that option which is suprising as it's ment to have everything!
Post #86059 8th Oct 2011 3:25pm
SteveMFr
Site Sponsor
Huh? I was not aware that there were different switches avail for the right side of the steering wheel.
Left has either the heated steering wheel or the recirculate air button (what a great idea that was: hey what do we do with cars that won't have heated steering? Uhhh Idunno. Gotta do something that wont make those cars seem better. Howbout we make the button recirculate air?
I thought all right side switches were the same from 2002-09.
So you don't have the bottom button on the right (also known as 'the sneezing man')?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #86065 8th Oct 2011 4:24pm
stu
i am not a phone crazy kind of guy and still use my Nokia 6230i which fits in the cradle and gives full functionality.
my wife has a Nokia X6 (i think) and it does exactly the same as mine but via bluetooth. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #86085 8th Oct 2011 6:19pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
The voice button on mine will not answer the phone - I need to use the satnav screen..... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #86091 8th Oct 2011 6:55pm
stu
i think the steering wheel buttons only work if the phone is in the cradle?? not 100% sure. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #86096 8th Oct 2011 7:00pm
CG-SC
Probably right - I am using a Blackberry Bold connected through bluetooth....... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #86100 8th Oct 2011 7:09pm
SteveMFr
Site Sponsor
No, the steering wheel buttons should work just fine with bluetooth only. There is no cradle avail for 99% of the phones on the market. And the cradle only does charging if it's not the old Siemns BitII phone..
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #86125 8th Oct 2011 10:38pm
barrieeld
Checked tonight I def don't have the voice control button I have the heated steering wheel though. Strange why it wouldn't have it...
Post #86135 8th Oct 2011 11:31pm
