![]() | Home > Technical (L322) > Approach Lights in Wing Mirrors not working |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 ![]() ![]() |
After a bit of a false start earlier this week I am going to have another go at investigating my approach lights.
So, how do I get to this relay? I take it we are talking about the fusebox in the glove compartment? No obvious relays there. Do I have to get behind the fusebox somehow. Can anyone point me at a wiring diagram for the interior lights for a 2005. Thanks David |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35729 ![]() ![]() |
have you checked the bulbs... ... - .- -.
Both bulbs checked and good.
i would look at rave, mines a 2005 and most stuff is the same ..all the other courtesy lights work i gather and you've checked the fuse.. ... - .- -.
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Check to see if the relay is in the boot compartment on the right side. |
Well of course. Fuse 14 should be blank, Fuse 17, 3 to the right, (for the approach lights) has a good fuse in it so that can't be it. Except on closer inspection the blank space is not 14! For some reason, 14 had a fuse in it, and the blank space was 3 to the right.... Fuse moved from 14 to 17 and all is right with the world. David |
Seems that FFRRs' like to move their fuses around when the owners aren't watching |
Oops! |
