Home > Technical (L322) > Completely shilut down |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6666 |
Sounds like either the battery's dead and not holding a charge, or the alternators not charging the battery? Got - 2017 SDV8 Autobiography in Loire Blue
9th Oct 2011 9:29pm |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
Most probably the battery is kaput (maybe due to possible alternator issue) - Do you have an idea how old it is? |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 |
Sound similar to when my alternator failed (symptoms, not circumstances) - everything working well, then suddenly no power, key no longer working. When these things run out of juice everything dies and the battery cannot support it for that long without the alternator |
9th Oct 2011 10:00pm |
Johninspain Member Since: 09 Oct 2011 Location: Murcia Posts: 7 |
The thing is it still won't play ball with a battery pack, it turned a little, and when I hook it to the battery of my other RR via some big leads it still won't give enough to turn over the engine, just clicks. There was some kind of electrical smell from down the side of the fuse box ! |
9th Oct 2011 10:15pm |
I'm sure I've heard that attaching jump leads doesn't work. Are you connecting it to the flat battery? It might be best to get that fully charged and try it again. Either that, or stick a fully charged battery in Got - 2017 SDV8 Autobiography in Loire Blue
9th Oct 2011 10:19pm |
just as alanm_3 has said - attaching jump leads /battery booster packs doesn't do your pride and joy a lot of favours and could cause damage if you try to turn the car overrepeatedly using these methods because the connections are never really 100% - this may cause the burning smell you have noticed
9th Oct 2011 10:44pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Does sound like the alternator has packed up. Had similar happen in my P38A. Got a load of lights and errors pop up as driving along. Stopped at traffic lights on a roundabout in middle lane during evening rush hour. Thought I would switch off to clear faults and then to carry on, but car dead on trying to restart. Great place to break down! Grabbed a towrope out of the back and stood by car for over 20 minutes waving it at all the traffic before before a van stopped and towed me to the side.
10th Oct 2011 1:26am |
rayc Member Since: 13 Sep 2011 Location: deal, kent Posts: 105 |
Sounds like the battery.
10th Oct 2011 7:36am |
When the alternator went on mine it killed the battery really quickly. The chap from landrover assist had a booster pack plus the umbilical booster cables from his Disco connected for over 20 minutes before there was enough charge to get the car turned over. Once it was up and running and the battery 'topped up' we took all the booster/jump cables off and put a meter across the terminals. The alternator was actively discharging the system. If you can get it started again check that you have over 14v when the engine is running, if not you could be looking at a new alternator and possibly a new battery depending on how deeply it has been discharged.
10th Oct 2011 9:17am |
Baben Member Since: 17 Oct 2010 Location: Kyalami Posts: 165 |
100% my experience also - wife's TDV8 (sport) battery died, there was no way I could jumpstart it, even with a D3 battery. Needed to fix the problem, put in a fresh battery, and then all OK |
10th Oct 2011 10:54am |
FFS it must be the alternator ! New battery on and car started fine, ran for one min them shut down again ! The bur if smell is coming from the battery ! |
10th Oct 2011 3:18pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
I have sucessfully used jump leads to start my TDV8 the other car though must have the engine running and preferably should be a diesel as petrol takes longer to start as I found out when connected to my next doors Micra. Present :2008 TDV8 HSE
10th Oct 2011 3:27pm |
