Home > Off Topic > Plumbers
Why? Dont mean to be a pest but house heating and boilers has never been something i've been "into" so know jack all about whats good whats not and what is needed. How do you work out the rad sizes? I know there measured in BTU's but is a 100BTU going to be much diffferent to a 200BTU etc? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #86563 10th Oct 2011 9:29pm
skippy
United Kingdom 2007 Range Rover Vogue SE TDV8 Rimini Red
hi there plumbers are so expensive i should know i am one Laughing but 4-4.5k seem alot if you are quite handy then go down doing it yourself copper has gone trough the roof at the moment for new and scrap, plastic pipe is as good as copper(25 years gaurantee) but thermal expansion is quite alot, its also alot faster than copper make sure you use pipe inserts though and the first meter from the boiler has to be copper.Boiler wise worcester and vaillant are the best at the minute but are quite pricey 30kw sonds about right the higher the kw the better the hot water flow rate, plumb center website has a program you input room sizes and it will tell you the kw for the rads the also do heta packs that will do rads boiler etc for a pack price if you want any more help let me know Thumbs Up 07my 3.6 tdv8 vogue se in red
Post #86570 10th Oct 2011 9:53pm
There once was a plumber called Skippy,
Was plumbing a lass who was a hippy,
And as he was plumbing
She said "Stop, someone's coming"
Said Skippy still plumbing....."It's me" Rolling with laughter Rolling with laughter Rolling with laughter
Post #86575 10th Oct 2011 10:04pm
Googsy
Rob
You should seriously consider keeping the back boiler also. I had this in my first house and should have used it. Instead I replaced it with a gas boiler and now that im in my newer house it has gas fired central heating and no back boiler. I wish I had as I have a stove that can also be plumbed into the back boiler and used to head radiators using coal peat and logs. Over the years this would provide a great saving for a small outlay upfront and i would seriously consider that as an option in addition to new gas boiler as you can switch between the two. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #86578 10th Oct 2011 10:18pm
Googsy the only thing my back boiler is good for it the skip!
The other fire isn't much better
Skippy that's handy to know. I've looked on the plumb centre website but can't find the calc you mentioned? What would have to be done to get the house certified if I was to do the work myself? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #86600 11th Oct 2011 12:00am
check stovesonline if you want to spend some cash up front and save a lot of money fuelling in the long run as its something im definately doing in our next house and even the FIL is thinking of getting a setup like it Smile
Just need to find a decent amount of wood and a woodstore Smile
Post #86608 11th Oct 2011 7:50am
Could be worse Rob , I had to get my boiler this ……
Hooked up to this Megaflow system …..
Post #86628 11th Oct 2011 8:39am
Mick I'm no expert but that looks a load better than what's in mine now. Found a good kit from here http://mrcentralheating.co.uk/index.php?ma...cts_id=737 seems like a reasonable deal.
Skippy would that sound like a good system and price? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #86650 11th Oct 2011 1:55pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
get a vaillant and use copper. 2004 black Vogue TD6
Post #86684 11th Oct 2011 4:54pm
skippy
sorry for the delay thats a good deal seen them alot in the papers never used them though same boiler as i have Smile as for the certficate you will have to let to get a gas safe engineer pass it to you can fit the pipe but as for the connections to the meter and boiler, fire etc this has to be done by them as for the website its plumb nation sorry not plumb center any more help let me know Wink
@47p2 i like the rhyme al have to have it on the van Very Happy 07my 3.6 tdv8 vogue se in red
Post #86832 11th Oct 2011 10:56pm
