Home > Technical (L322) > 4.4 petrol lpg remap
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
my friend who fixed my car and serviced the lpg said it would be a good thing to get it remapped as well as he said i could get 30-40 bhp more and 5mpg better as well because the gas is 100 something ron he said thats how you can get that massive boost of bhp
any thoughts on this
4.4 petrol/lpg
Post #86956 12th Oct 2011 4:51pm
It always intrigues me just how you can get more BHP and more MPG with a remap Shocked
Post #86961 12th Oct 2011 5:00pm
dannyp15
me to but its all about getting the most out of your ecu
Post #86962 12th Oct 2011 5:01pm
afaik there are two types of mapping, one for more power and the other for more mpg...each map is individually tailored to one or the other.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #86965 12th Oct 2011 5:03pm
dannyp15
you can get it in between the both so you can get both mpg and bhp
Post #86967 12th Oct 2011 5:05pm
that would be standard then...i dont think you can tbh...when i had mine done the bloke asked which one i wanted and didnt give any other options.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #86970 12th Oct 2011 5:07pm
dannyp15
he also said its much smoother through the gears and more responsive
Post #86972 12th Oct 2011 5:08pm
thats one thing a map does it makes the gears kick in differently for mpg and for power..for instance for the mpg map the higher gears kick in quicker so you use less fuel.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #86975 12th Oct 2011 5:11pm
Danny,
Someone once said "if something sounds to good to be true, it usually isnt." This kind of fits what you have been told. I would be happy to be proven wrong though. A few garages do offer a try before you buy type thing. might be worth chatting to your mate and get him to do that. Do the map, if its no good or not what he says get him to put the old map back, if it works you can hand over the money. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #87024 12th Oct 2011 7:12pm
bozmandb9
Rather than a remap, what you could do is get your cats removed! This could give you a power boost and better mpg!
Big J is your map for remaps. Thumbs Up Range Rover-less at the moment - Pining!
Post #87044 12th Oct 2011 7:55pm
ric355
Re: 4.4 petrol lpg remap
4.4 petrol/lpg
You won't get a massive boost in power. The theory is basically correct - the RON rating of fuel refers to its ability to resist pre-ignition. A higher RON fuel allows the ignition to be advanced which can help the engine generate more power, but two things to consider: (1) The effect will be virtually nothing without changes to the induction and exhaust system, and (2) if you remap for 100 RON fuel then you need to run on 100 RON fuel all the time, so if you switch back to petrol you'll lose power and if it's 95 RON then probably get pre-ignition under high loads which will damage your engine.
At best I'd say it'll be worth 5-10hp on a cool day and it's not worth it. You won't even notice with an auto box.
It's a different prospect for a turbo engine as you can just increase the boost and chuck more fuel in for a remap, and also advance the ignition for higher RON fuel but you're still stuck with that rating of fuel post-mapping.
A remap will eliminate flat spots or remove restrictions that have been inserted for efficiency or emissions reasons, but these things will just make it use more fuel to deliver more power. Practically speaking you can't have both more MPG and more power at the same time (unless you change the design of the engine!).
Post #87082 12th Oct 2011 9:37pm
The only real way to do this with log is a better induction kit, and he cats ripped out then the remap Smile
This from someone who has had lots of power from an lpg installation but with other tweaks as well...
Post #87088 12th Oct 2011 9:51pm
BBS SPY
Cyprus 2003 Range Rover HSE 4.4 V8 Java Black
Remaps can, and have been debated until the cows come home.
It seems to be highly competative and very dynamic industry, invoking much argument and opinion on any and every forum and is truly a moderators / forum owners nightmare.
IMHO most remaps can possibly smooth out power delivery and produce extra power and / or economy depending upon how the vehicle is then driven.
But when i first got mine, from possibly the most respected and renowned there is, the improvement in performance was pathetic and worst still my vehicle started to smoke very badly on any acceleration.
I quickly learned that a remap does not provide any kind of quick fix to poor power delivery problems from an existing situation, and actually high lights any existing problems.
I don't know how long the split in my Intercooler hose had been there, but it was a simple 10 quid 2 minute fix, and a mini service replacing what looked like a bit of carpet for an air filter was also cheap and quick to do. I was also astounded to discover how much crap was stuck on the front of my Intercooler, dead birds, feathers and leaves to name but some.
The results of a simple bit of cleaning and maintenence were simply astounding.
I am personally an utter lead foot kinda guy, and truly appreciated the very impressive GTI like appeal of my own TDV6 remap until all the petrol stations closed and i was forced to see how far a tank would actually take me when used in moderation, which was equally impressive.
IMHO getting a remap is a no brainer, regardless of if you want better performance or economy, but it is no substitute for poor maintainence. 2003 4.4 HSE
Post #87263 13th Oct 2011 7:47pm
BigJ
United Kingdom 2005 Range Rover Vogue 4.4 V8 Stornoway Grey
Mine is a 4.4 V8 BMW M62 engine and remapped by me.
It is also LPG.
It is tweaked to the gas and has sharpened it up and most importantly sorted the throttle pedal being so dull.
I will be improving it further as it still needs a bit more at lower RPM.
I'm very pleased with it. Used to have:
2005 FFRR 4.4 Vogue - BRC LPG Conversion & Remapped
Now have:
2008 SSRR 3.6 TDV8 - HSE and plenty of toys
Post #87339 14th Oct 2011 10:08am
A1GSS
How are you doing your own mapping? Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #87353 14th Oct 2011 12:03pm
