Home > Technical (L322) > Can you use Range Rover Sport wheels on the Full Fat?
inkiboo
Switzerland 2007 Range Rover Vogue SE TDV8 Java Black
Picking up my first full fat on Friday (MY2007 Vogue SE) and would like to get a 2nd set of wheels as a winter set out here in Switzerland.
Will Sport wheels fit the Full Fat?
Post #8701 24th Nov 2009 9:01pm
I've seen FFRR's with Stormer 20" alloys but wouldn't like to say for sure. Discovery 4 HSE
1993 90 Tdi
Post #8703 24th Nov 2009 9:40pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
I think they will fit, but are wider and if they come with tyres then they will be no good, due to the load rating.
Post #8704 24th Nov 2009 9:44pm
inkiboo
Thanks for the advice; the plan was to have the Sport wheels as the Summer pair and the Full Fat ones for Winter. Given I would have to change the Sport tyres, I might just get a 2nd set of Full Fat wheels.
Post #8706 24th Nov 2009 10:03pm
probably the cheaper option too. Discovery 4 HSE
1993 90 Tdi
Post #8707 24th Nov 2009 10:16pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
RRS 19's are 9J with 255/50/19's fitted
FF are 8.5J with 255/55/19's
Stay above 109 load index also the 50's will have a smaller rolling radius
Yes Adam RRS rims appear to be cheaper at times just be carefull of some ebay ones try FFND on here he can get hold of wheels Thumbs Up
Post #8716 25th Nov 2009 4:24am
nbunney
Thanks Ken
I knew you would come up with the figures Bow down
Post #8727 25th Nov 2009 9:41am
ken
Also no probs with 255/55/19 's on RRS rims Thumbs Up
Post #8728 25th Nov 2009 9:58am
You're better off looking on fleabay and getting a set of FFRR wheels, there's loads for sale all the time cos so many people want to bling up to 22" idiot wheels! Discovery 4 HSE
1993 90 Tdi
Post #8733 25th Nov 2009 10:11am
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
They should fit fine, at least the 20's.
I would love to have them as the Sport uses 275 section and the FF 255.
That means that the Sport's dimensions are also used by Cayennes and others. Which in fact turns out to be easy to find cheap tyres.
For the FF on 20's, only two manufacturers make those tyres with the correct 109Y rating, Pirelli and Continental. And that means lots of €€€€€€€€€€ for each tyre.
On the Sport with 20's you have a lot of choices beacuse most of tyre makers do make those dimensions, meaning less €€€ per tyre.
Post #8803 26th Nov 2009 12:02pm
Full fat not diet
England 2004 Range Rover Vogue Td6 Zermatt Silver
If memory serves me correctly the contis on the RR Sport are the same dimension as the Cayenne but with different numbers - they have a N0 on the end so they are exclusive to Porsche. Cant remember if there is any variation to the compound or tread pattern - God i am boring to have retained this Rolling Eyes Yawn
Post #8804 26th Nov 2009 12:09pm
nbunney
Yes you are right about sizes, but be carefull of the load rating values, as RRS tyres are not strong enough. FFRR needs 109Y''s or above. Not sure if that's the same as the Cayennes and others.
Post #8812 26th Nov 2009 2:36pm
