Home > Technical (L322) > Rear brake Light
barrieeld
Rear brake Light
just noticed my rear high brake light doesn't seem to be completely flat it seems a little up and one and like it its not being held down properly?
Is it held in by clips ? Just wondered as i didn't want to start messing with it until knew what to assemble it in the first place.
Thanks
Post #87554 15th Oct 2011 4:11pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
mine was slightly raised to the lefthand side. Looked at it and the top had 'come unstuck' / warpped from the back plate. Due to water egress i decided to change it!.
Post #87570 15th Oct 2011 6:04pm
That's funny I noticed mine was the same just last week. 2008 MY Supercharged
Post #87579 15th Oct 2011 7:33pm
barrieeld
This is exactly what I have a slightly raised left hand side...so is it warped? How much is a new one?
Post #87616 16th Oct 2011 1:19am
DavidP
the part was approx £55, easyish to change. Remove 3 bolts from upper spoiler. Remove inner upper trim. Undo a few screws of light and unplug electrics. Slide light unit out. Only thing to note was the lagre rubber grommet needs to be moved to the far r/h side.
Post #87618 16th Oct 2011 8:33am
