Home > General > heated front seats
iancollins
England 2016 Range Rover Vogue SDV6 Causeway Grey
heated front seats
can anyone who has a new 2011 4.4 tdv8 vogue
check their front seat heating
does it get unpleasantly hot on both settings ????
my older l322 2008 never used to get this hot and am wondering wether this is common
help would be appreciated Very Happy
Post #87760 17th Oct 2011 4:45pm
mzplcg
No more so than the average Vindaloo. Rolling with laughter
Sorry, that didn't help much. Embarassed
Dom.
Post #87762 17th Oct 2011 4:47pm
iancollins
come on guys
i can't be the only one with a 2011 4.4tdv8
Post #87801 17th Oct 2011 9:40pm
johnson1
They do heat up quickly. Is your leather perforated? I find my 'dials' offer a fair amount of adjustment though...the different settings are noticeably different. Are there 2 stages on the Vogue? Mine has 3 so maybe I have a low setting and you have Med, High?
Post #87813 17th Oct 2011 10:36pm
Shaun6
I have a 2011 VSE and the heated seats have 3 options for heat and 3 options for where (seat cushion, seat back and both), does not get too hot on level 3.
Regards
shaun
Post #87833 18th Oct 2011 10:13am
iancollins
mines just a vogue
has 2 heat settings
gets really hot every now and then
its as if theres a thermostat that sticks
Post #87843 18th Oct 2011 12:48pm
Rolo
United Kingdom 2012 Range Rover Vogue SE TDV8 Orkney Grey
I have an SE with the perforated leather.
Takes a while to warm from start up, but once engine is warmed up, very quick to heat.
I found the 3 settings pretty good. Not sure why they won't let you only have the bum heat on though - it's either back & bum or just back.
If it's on full for more than 10 / 15 mins, I do have to turn down a notch before I get betty swollocks Rolling with laughter
I think it works a treat........as well as the lovely cold air.....brrrrrrrrrr Thumbs Up
Post #87855 18th Oct 2011 3:12pm
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
Our seats don't heat that quickly. And sometimes randomly switch themselves off and back on (when no where near switch off temp). We have had it back to the dealer who can't find any problems.
On the times it does work it does get toasty but not Mad(r)ass hot.
First thing in the morning they are very slow to heat. Not sure if related to battery juice availability....
Software update a couple of months ago didn't solve it either.
Grant
Post #87890 18th Oct 2011 7:33pm
Rolo
Do the Vogues have electric heated seats then rather than "hot air" ?
My SE heats by blowing warm air through the perforations.
What about if you have the cooled option with perforated on the vogue, does that then have the same as the SE ?
Post #87958 19th Oct 2011 12:12pm
iancollins
i think vogues have electric front heated seats
Post #87964 19th Oct 2011 1:00pm
johnson1
I'm pretty sure my Autobiography uses a heating element for the heating part front and rear and cooling fans for the cooling part front and rear? I cannot hear the air coming up like I can when the cooling is on maximum?
Post #88000 19th Oct 2011 2:32pm
Rolo
I'm sure mine heats by air because you can hear the fan turn on & off to keep the temperature constant. There's a very slight wooshing as it goes on & off......Definately feels warm holding hand above, although the airflow is so slight you can hardly feel it to touch apart from the warmth.
Post #88152 20th Oct 2011 4:55pm
johnson1
Definitely air on mine too! Checked on the way home.
Post #88241 20th Oct 2011 11:42pm
