![]() | Home > Technical (L322) > can suspension compressor be stripped/repaired? |
| marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916
Started getting a regular "air susp inactive" on the dash and it reads as pressure static when filling so i am guessing my compressor is getting tired. I regularly rebuild P38 compressors with a piston/seal kit off ebay and wondered if anything was available to overhaul the pump on the FFRR? or do i have to shell out for a complete unit and throw the shell away(mine has the gas tank where the compressor turtle should be and the compressor is mounted t the side
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
There is nothing out there yet Paul. Looked into it quite a bit. I'm working on this with another member but not had anything good to report yet. PrestonAir are working on an prated compressor but that has been on the back burner for a few months. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Thanks Rob, will see what happens. Not a problem at the mo but i like things to work as they should |
| letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854
yea i had to buy a new turtle shell for mine, £270 when all prob i needed was a couple of rubber seals.... |
@Daveo the compressor also has a thermal cut off. I was looking into plumbing a second compressor into the system using a simple relay system to cut the power when the main compressor s/d, it should be quite simple in theory but haven't got round to doing it yet. The compressor is capable of pumping 14bar I think. Found some technical drawing on the Wabco website but there were no details about piston ring dimensions. Swast (Adam) has my old compressor stripped and has a guy we work with making up a few piston rings which might work, as that's the part which fails. The elec motors are pretty robust it's the piston rings that fail/ ware resulting in slow and poor performance. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307
i had a chat with tech at webco,try to find out what other compressors shares the same parts, they do repair kits for other compressors in there range but it seems like land rover holds all the cards on this one, they would not even tell me what bar it should push..so i have started looking for some diagrammes on line. V8 facelift Range Rover Autobiography 22" wheels.
| paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222
Hi All
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Joe, they are a piece of |
I had a reply to my email to Landrovermall's Goswin de Rouwe He is looking at this but has nothing to offer at the moment. I never got round to stripping mine down, the weather was nice and I found better stuff to do!
| SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
Can't have too many pics, but there was a thread about 2 months ago with a compressor teardown by Adam (swast4).
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1564
Not necessarily. Mine used to fault with this error from time to time, yet it still managed to keep the car at normal height for 1000's of miles. The problem was actually the pressure sensor itself on the tank. It wasn't registering an increase in pressure when the system started up and did a pressure test. The pump itself was fine and managed to pump the air bags directly. Just the sensor duff. V8 or else ... |
| RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380
Hi Fisha, Where is this sensor ? is it actually in the compressor unit. mines is taking over 1 minute to actually get into off road height which makes me think that the compressor is on its way out. the only time my suspension started causing issues was when my tyre well was filled up with water due to the tailgate being left open by my brother so im not suspecting anything at all |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
From what I know the compressor fills the air tank and the tank distributes the air to whatever corner requires it. If the compressor is weak it will be slow filling the tank and therefore throw up faults |
| All times are GMT |
