![]() | Home > Technical (L322) > Do I need to replace all 4 brake sensors? |
only two sensors james and only replace the one which is worn.. ... - .- -.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
splendid. Many thanks. night night Stan |
cheeky bar steward... |
Fr_Raf Member Since: 20 Nov 2010 Location: Lyon - Paris Posts: 147 ![]() ![]() ![]() |
I replaced my disks and pads 2 months ago.
only two sensors raf, one on the front near side [afaik] and one on the off side rear.. ... - .- -.
Thank you Scarey, nothing different here. One in the front left, and the other on the rear right |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Be carefull removing them as most will shatter as the plastic gets brittle with age and heat,,,
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
The vehicle only needs one sensor - reason being the pads are supposed to wear at the same rate in normal conditions 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Yes, works well that system, except when they don't wear at the same rate, which is what caused a three hour ride in a big yellow taxi on my way back from Scotland! |
