![]() | Home > Maintenance & Mods (L322) > Wheels cleaned but lots of oil..? |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
Hi Folks
Thanks Mate.
Depends how much grease you lost as to whether it will require a top up.
It's deffo a jubliee as per your first pick. It is not however on that multi layered rubber pic - There is nothing on that. It is inboard more (towards the center of the car) on another rubber gator..??!!??
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
No. Either end of the gator need to be sealed by the bands/clip. Inside the gator is a CV joint and the gator holds the grease to keep it lubed. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Each driveshaft (one on each wheel so 4 in total) should have 2 rubber boots and 2 steel band clips per boot |
Thanks
The small end can be done with a jubilee clip as it won't foul anything but the big end needs a proper steel band, and no......a cable tie doesn't work.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
If it's a jubilee clip it's not origonal but where it's located I can't see why a jubilee clip couldn't be used.
