Home > General > colour coding grill surround - advise needed
RR8701
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
Right guys i am really not keen on the grey bit that runs outside the grill, how to a first remove this and secondly what is the process on spray painting it. Smile
Post #89109 27th Oct 2011 1:38pm
If it's like mine on the 06 Model lift the bunnet and there are 3 screws at the top undo them and IIRC there are two clips at the bottom just watch how you release them , take it off either mask the area you do not want to spray on the grill , clean , prime it , spray it ... Thumbs Up ====================================
Post #89135 27th Oct 2011 3:37pm
RR8701
thanks mick,
i have tried some pray painting in the past and its one of those things ive never been able to do to my own satisfaction its really annoying lol
i have taken your advise and also read up on the halfords website, I would imagine a good clean of the part is first stage,
then prime it with something like the following
http://www.halfords.com/webapp/wcs/stores/...yId_165495
I would be fine up to this stage, the stage i have trouble at is the actual spray paint stage, i understand it should be thin coats applied many times however do you really need to sand it down with wet and dry sand paper and if some which exact one would you use, i know you get different abbresive levels....
I would then use this java spray paint but i assume id need the lacquer too, the java black was a metallic paint was it not ?
http://www.halfords.com/webapp/wcs/stores/...yId_165505
thanks Smile
Post #89146 27th Oct 2011 4:06pm
You need to use plastic primer
Post #89147 27th Oct 2011 4:10pm
RR8701
nice one 47p2, i got it Thumbs Up
Post #89149 27th Oct 2011 4:21pm
I think I only paid £50 to have mine done professionally - I had the side vents done at the same time which will have brought the price down a bit, but I know I would have had runs in it if I had tried
Post #89180 27th Oct 2011 5:44pm
Chipsaway done my grill, side vents , wing mirrors, bonnet vent, for about £50 as well … saves all the hassle of doing it yourself ... Thumbs Up ====================================
Post #89182 27th Oct 2011 5:51pm
RR8701
lol, hmmm 50 quid seems realllllyyyy good value lol, i actually wanted to learn this new skill but if they are going all that for 50 quid i might be tempted tbh
thanks for the contacts guys, ill give them a buzz tomorrow.
mick: you said you got your bonnet vent done, could you post a picture of this please Very Happy Thumbs Up
Post #89188 27th Oct 2011 6:26pm
Will have to be tomorrow too dark now to take any pics , so what colour is yours …. Whistle ====================================
Post #89190 27th Oct 2011 6:35pm
RR8701
haha cheers mick id appreiciate that. Thumbs Up
Post #89209 27th Oct 2011 7:46pm
fisha
Trick with rattle cans is a bit of patience.
Once you realise that you dont get a perfect coating on the first pass, you'll do fine. Its all to easy to say ... oops missed a bit there, and go back and try and spray it immediately. At which point, you overload the surface with paint and get runs.
If you miss a bit, leave it to dry the right amount of time, then go over it again on the next pass and do the pass from a different angle to get the paint inthe right place.
Other quick tip, dont spray to close, you'll get runs too. that 30cm distance works for a reason.
You can get good results with rattle cans. I used to do my horse trailer wheels with them, likewise an old set of RR alloys came out well, but only once I learned to take my time and leave missed bits will next time. V8 or else ...
Post #89253 28th Oct 2011 8:59am
Here you go ….
Post #89270 28th Oct 2011 12:07pm
