Home > Technical (L322) > 2007 TDV8 Tow Bar Wiring Issues
stu
i have just wired my car for 13 pin electrics and that is correct, there should be one permanent live feed which lets you have 12v power for lights etc and one ign feed which in conjunction with the caravan relay should kick in to power the fridge and charge the battery. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #87880 18th Oct 2011 6:36pm
dhallworth
The Range Rover came with 13 pin electrics and so did the caravan.
We've managed to resolve this issue... The wiring loom the Range Rover should have fitted to it is YWJ500460. This has a relay for the caravan electrics and has the right coloured wire going to the right place.
The wiring loom that was fitted to our Range Rover was YMZ000020. I'm not sure what this wiring loom is but the colours in the plug don't match anything I can find a reference to and there was no relay fitted.
When Googling the wiring loom number Rimmer Bros. have one listed for around 50 quid, the correct loom is just over 100 quid, but other then that I can't find out what it's for.
Anyway, we fitted the new (correct loom) yesterday, tested it this morning and normal service has resumed.
Thanks for the pointers chaps.
Post #88592 23rd Oct 2011 5:28pm
stu
just back from a week away in "The Lakes" with my plastic palace, all well with towing and towing electrics.
glad you got sorted too David!!!
electricery is a funny thing and Land Rover as i have said before use non standard colours in their looms, probably to stop us plebs from fiddling!!
anyway all is well and that's the main thing... Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #89317 28th Oct 2011 4:21pm
