![]() | Home > Technical (L322) > LED Side Light Bulbs - Flashing at start up |
This is the norm, its your lcm checking that they are working, the lcm sends a small voltage to check for a resistance and that tells the lcm that its working, its only a small pulse not enough to light a normal bulb but as leds work on lower voltage it causes it to flash..my ones do it and my fogs as well as my high beam so you can imagine its a bit like a christmas tree at night.. V8 facelift Range Rover Autobiography 22" wheels.
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Thanks Daveo - I was wondering why they did it - It actually looks quite cool - I can imagine what yours must look like |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
My flash does it also |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
mine flash and as said it does look good on start up.. ... - .- -.
trafpol Member Since: 15 Jun 2011 Location: Surrey Posts: 141 ![]() ![]() ![]() |
Mine flash too I just pretend its the alarm turning off and say nothing just carry on as normal... |
to be honest the led's in the high beam are not that great, they look fine and are the same colour but you dont get any light out of them, but i have a set of xenon's coming that are ment to have the flash option, if they work then "i will have what i like to call" tri-xenon |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 ![]() ![]() ![]() |
Hi Daveo, did your bulbs arrive? what they like? where did you get them ?? |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
I would also be interested in the fogs.
