Home > General > 54plate RR Vogue
Luckyluciano
54plate RR Vogue
Hello all,
I have been looking for a RR for a little while and found one over in Bedfordshire.
Drove up to take a look this morning and all looks good. Body work is in good
condition, all the electrics work inc the steering wheel motor.
So went for a test drive and the only thing I picked up on was a knock coming from the offside
front when turning. It was not constant but was pretty loud.
The dealer said he thought it was a drop-link? They had replaced the near-side drop-link the week
before.
He did say he would send it the local LR place to get it done.
Any thoughts what it could be?
Also if I may, where do you guys buy your parts from? It needs a couple of bits like the
centre console armrest needs replacing(the little bit that lifts to unlock it) and one of the side repeaters
has a crack in it and I would like to replace them with clear ones.
Thanks in advance
Lucky.
Post #89390 29th Oct 2011 3:27pm
The knock could be a drop link but could also be a CV joint or even a wheel bearing. Make sure you get it sorted before you hand over your money. Smile
Post #89391 29th Oct 2011 3:38pm
see what the end result is when you get the range back from the dealer, if the noise is gone then all is good.
as for bits and pieces ,pm dan the parts man at duckworths or if he cant help then ebay is a good bet.. ... - .- -.
Post #89392 29th Oct 2011 3:40pm
Luckyluciano
Thanks Guy's Very Happy
Just noticed Scarey your in Swindon, me too.
Post #89393 29th Oct 2011 3:45pm
Someone has to live there Very Happy
Post #89394 29th Oct 2011 3:53pm
Luckyluciano
It's not that bad, honest. Wink
Does anyone know what the cubby hole opening handle thingy is called?
Post #89397 29th Oct 2011 4:01pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Yeah, it's called "cubby hole opening handle thingy" Laughing No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #89400 29th Oct 2011 4:38pm
Luckyluciano
The car has gone to MRH Land Rover specialist in Hertford and they reported that the knock was a split air bag on the front suspension?
Does anyone know this specialist and can anyone explain what that problem is?
Post #89664 31st Oct 2011 2:27pm
Well how the heck was this not obvious when you viewed the vehicle. A split air bag would give you an air susp inactive message, the car would be down on that side, and the ride would be terrible. Its not recommend to stand the car on an empty air bag, let alone drive it. ( I am in the process of changing my front air suspension!)
Maybe time to walk away.....? .
Post #89665 31st Oct 2011 2:35pm
Luckyluciano
Thanks Joe,
When I test drove the car it was fine, no errors and the ride was good. I even checked the ride height going up and down, all ok. I might give them a call and ask what they found instead of the info being second hand.
Post #89667 31st Oct 2011 2:47pm
are you looking for something in particular lucky cos i might be tempted to sell mine.. ... - .- -.
Post #89670 31st Oct 2011 3:00pm
Luckyluciano
Scarey, It's going to be the other halfs car as I won't let her drive mine Wink
Post #89685 31st Oct 2011 3:41pm
humbug, you cant have a female driving a FFRR .... Laughing ... - .- -.
Post #89687 31st Oct 2011 3:44pm
Luckyluciano
lol She's less likely to go sideways in the RR Shocked I have to get both front wheels refurbed on mine after she last took it out Big Cry
Post #89689 31st Oct 2011 3:58pm
Luckyluciano
Finally got hold of MRH and spoke to the guy working on the car. He said the knock is due to the ball joint and he will replace it tomorrow.
So it has nothing to do with the air bag, Salesmen!
Post #89711 31st Oct 2011 6:31pm
