![]() | Home > Technical (L322) > [SOLVED!] Tight Bastard! Recommendations on Seized Bolt? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
In the process of changing a front air spring.
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
If the socket, or spanner is a good tight fit, you could use a bottle jack or trolley jack to to put extra pressure on it. Or if you have an extending wheel nut wrench they are great for extra force on nuts/bolts. Previously..
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1557 ![]() ![]() |
I have 2 breaker bars for things like that.
See what was needed just to undo the nuts (they have come off OK, it's just the lower bolt that is being stubborn)
If the nut is off the lower bolt should push through, it isn't threaded.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3986 ![]() ![]() ![]() |
If you have a good fitting socket, 6 point not 12 point you can use a breaker bar/ tube and prop the end off the ground with a brick or lump of wood and gently lower the car jack. Gravity is a wonderful thing when backed up by a b |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I have a five foot long, 750lb torque wrench for such occasions, plus plenty of BFI (Brute Force and Ignorance!!) |
We have a five foot bar for those bolts! If you have it moving slightly then just keep moving it a little at a time (spraying it with WD40) and trust me it will get easier and easier. We have taken 2 hours to work those bolts out sometimes!
Leave nut on end of bolt if you're going to bash f |
Thanks to all for advice and encouragement, with the first few attempts failing, had to walk away and think about it, so more of the same tomorrow. I will persevere with working the bolt round rather than beating the s |
Success!
Glad you got it sorted.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
As my dad always said "you know you have done a good job when blood has been shed!" [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
