Home > General > PDC
barrieeld
PDC
none of my front sensors seem to be working...ive tested them and no ticking noise coming from any of them, cold it be all the sensors are faulty or is it most likely the pdc ecu?
Anyone had this issue?
Post #89483 30th Oct 2011 1:19am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Hi, I've posted on this.
For mine it's the PDC module. I checked the wiring and then swapped the plugs (it's pretty easy to unclip the plastic housing as they are keyed connectors)
The modules are cr4p to be honest and some members on here have had two or three.
http://www.fullfatrr.com/forum/topic6801.h...ors+solved
Post #89487 30th Oct 2011 10:08am
barrieeld
Hi there whats the best way to check if its the module...just turn around the connections on the pdc ecu in the boot? If this makes the front work then i know its this?
Is there anything i should be made aware of before i dive right in and start mucking about with the electrics....don't want to damage anything?
If this proves to be unsuccessful how easy is it to swap sensors from rear to front to check?
Anyone have prices for both individual sensors and a replacement ecu module?
Post #89494 30th Oct 2011 10:42am
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
the front ones can also be disabled via test book, mine didnt work when i first bought it untill it went in for a software update and everything was reset to factory then they worked for a little while until i had a wiring fault. Rolling Eyes
Post #89572 30th Oct 2011 9:46pm
