![]() | Home > Technical (L322) > Door Locked Shut |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3986 ![]() ![]() ![]() |
I think you will find the two screws holding the lock "U" bolt in place are too tight to undo using slots cut in the rear.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
WOAH !! Stop! |
Can't see any great problem grinding off the fixing plate inside a B pillar.
Ruadh
Ruadh Member Since: 03 Nov 2011 Location: Dublin Posts: 28 ![]() ![]() ![]() |
Many thanks for the replies - a problem shared is a problem halved etc!
WOOLTON Member Since: 15 Mar 2010 Location: Liverpool Posts: 21 ![]() ![]() ![]() |
I had a similar issue with my passenger door a couple of weeks back. Door locked shut and wouldn’t open. I was about to take it into a local RR specialist but decided to "tweak" with the fuses which operate the doors locks which opened the door! Don’t know if this was just a one off / a bit lucky but it worked to open the door (although the lock was still broke). Ordered a new lock from Dan at Duckworths and had it fitted for £35. Works great now. |
