Home > General > Lpg V8 at last
SparkyPhil
England 2005 Range Rover Vogue 4.4 V8 Adriatic Blue
Lpg V8 at last
Hello everyone again
I have finally got my Range Rover, it is a 4.4 V8 on lpg 2005my adriatic blue. Well after getting the oil changed and the lpg serviced (one lpg injector was leaking)it runs really sweet well pleased with it. Now the questions I am convinced it as got a fbh, it is turned off via the touch screen and the timers are off but every time I unlock the car I hear a fan come on down in the passenger footwell area but it only last about a minute, so if this is the fbh How do I turn it off?
thanks Phil
ps I will get some pics up soon
Post #90487 5th Nov 2011 1:07pm
The fan always comes on for a minute or so when you open a door or the boot or the bonnet
Post #90490 5th Nov 2011 1:35pm
fbh should be located near the near side wheel arch..if its on your touch screen switch it on and see where the sound is coming from.. ... - .- -.
Post #90510 5th Nov 2011 4:09pm
SparkyPhil
Thanks for the replies, I have tried switching it on but when I press the on button it just goes straight off again, the heater/fan does not even come on.
Post #90524 5th Nov 2011 5:20pm
i think you'll find that the outside temperature must be below 5 degrees? to have it work.. ... - .- -.
Post #90537 5th Nov 2011 6:35pm
SparkyPhil
Thanks for the info 47p2 & Scarey much appreciated
Post #90553 5th Nov 2011 7:35pm
K20FTY
England 2003 Range Rover Vogue SE 4.4 V8 Java Black
I'm sure i've read somewhere that the fan you hear is an internal one to draw ambient air over the internal (cabin) temperature sensor, so that when you start up, you get a realistic response from the heater/air-con, as it's 'pre-measured' the current cabin temp. 2003 L322 Vogue SE 4.4 + LPG
2005 Aprilia RSV Mille
__________________
Some people just need a high-five.
In the face.
With a chair.
Post #92541 15th Nov 2011 10:26pm
sounds reasonable.. ... - .- -.
Post #92550 15th Nov 2011 10:36pm
