![]() | Home > Technical (L322) > Check engine light - again..... |
what was the error last time... V8 facelift Range Rover Autobiography 22" wheels.
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
What was the fault code last time? Mine seems to come on sometimes with code 430, something about catalytic converter efficiency. I reset it with the IID and drive on happily. Never an issue, just slightly annoying. Great to have the IID and be able to reset it so quickly! |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
My SC displayed a transmission fault - limited gears error message followed by the EML lit when I turned the ignition on today, I cycled the ignition switch and the message has gone but the EML remains lit. The car drives fine, so I'm going to leave it for a few days to see if it clears itself.
EML dont sound like the result of a transmission fault, this would come on due something with the engine, not sure i have read that the batt probs would bring on the eml but some one on here may of had it, but my guess would be that its a fault on the engine system, check the fault again and ask for the error code.. V8 facelift Range Rover Autobiography 22" wheels.
just noticed we have two members with the same prob.. V8 facelift Range Rover Autobiography 22" wheels.
would an eml fault be due to an injector fail.. ... - .- -.
My battery was replaced less than 12 months ago, whilst it could be faulty I think it's unlikely to be the cause in my case. |
true, i think the fault is with the engine, yes could be an injector,coil or sensor but i think the best and only way is to have the fault read, V8 facelift Range Rover Autobiography 22" wheels.
A common cause of the eml coming on on petrol engined cars is a fault with an oxygen sensor. The V8 has 4 |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Almost all EML lights are due to emissions, and as stated most are O2sensor problems. My last one was a bank running lean. A quick reset and LPG retune and 8months later still hasn't returned. When I have checked recently had an O2 sensor wide open error so guess I have one on the au out. Think they are about £50 each so not massively expensive. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
LostInSpace Member Since: 28 Apr 2011 Location: Pulborough, West Sussex - ex NZ Posts: 107 ![]() ![]() ![]() |
@ bozman - Fault last time was running lean on bank 1-4, but I didn't get the actual code.
IID = http://www.fullfatrr.com/forum/topic7073.html ... - .- -.
Running lean could also be an air leak on the induction side. The engine getting extra unmetered air |
