Home > Technical (L322) > Tyre rotation - good or bad idea?
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Just acquired 5 wheels and tyres (thanks Dan). What is the general feeling on rotating the tyres on a FF. My existing tyres seem to wear quicker on the outer edges of the front (don't know if that's normally the case). My old spare is a different size so has never been used except for emergency (this seems rather a waste of a good tyre).
I was thinking of rotating my new tyres every few thousand miles to even out wear, possible combining the spare in the rotation. I know this will mean my tyres will all require replacing at the same time and they are not cheap, but I don't cover very high mileage so they should last me quite a time. I know there are various theories on rotating tyres but I'm not that familiar with wear characteristics on the FF.
Any thoughts from long standing users? No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #91245 9th Nov 2011 5:23pm
if you have the time and the tyres arnt directional then why not...the normal change is fronts to back when the fronts have gone to far on the edges.. ... - .- -.
Post #91249 9th Nov 2011 5:37pm
Re: Tyre rotation - good or bad idea?
Have the geometry checked, it shouldn't wear unevenly Big Cry
Post #91252 9th Nov 2011 5:39pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Unless they're Craptinentals then they'll always wear the outside edges!
Post #91256 9th Nov 2011 5:49pm
Vogue
mine haven't and she's on the 3rd set of tyres - even right across the tread. Goodyears, Pirelli's and Vreds
Post #91287 9th Nov 2011 9:36pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Mine are even across the tread, I was expecting some outside wear (my old P38 did that).
My AT 2's have done 38,000 miles now, with no rotation.
Post #91290 9th Nov 2011 9:44pm
tsadpt
+1 even wear.... Also, there is very little difference in fron vs rear wear, so I can't really see much point in tyre rotation...
Post #94057 23rd Nov 2011 10:55pm
Mine wear on the outside edge but it depends on how much 'progress' you wish to make round corners and i live somewhere full of tight bends and roundabouts on the journey to work and to the PIL's Smile
Swapping them around will even out wear if your fronts get worn quicker but also means you'll need to replace the whole set when the time comes. Or just buy another set from Dan and sell the old set on as it seems the most economical route these days Smile
Post #94092 24th Nov 2011 8:36am
CUE99T
Whats peoples view on 22" Toyo tyres? Overfinch seems to use them......... all smug in my new plug!
2021 Westminster Black D300
2013 Vogue SE - gone
Some Porsche Cayenne guff pretending to be a 4x4!!
2006 Vogue
2004 Vogue
2001 Vogue
Post #94382 25th Nov 2011 1:33pm
RR8701
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
Hi CUE99T,
My brother in law is quite into his cars, much like myself and he has always praised the toyo tyres, saying it gives the best value for money next to much more expensive tyres.
Read some reviews online there will be quite a few i would imagine. I havnt experience them myself, the only thing that might make me through caution to the wind is looking at 22" tyres, but if overfinch use them then i prob wouldnt really give it a second thought.
Post #94390 25th Nov 2011 2:20pm
