Home > Technical (L322) > Yet another gearbox question.
T24RES
RRPhil wrote:
If it were mine, I'd drain & refill every 20k miles (which will replace about half of the fluid) and replace the filter every 40k miles. I emphasize that this is just my personal opinion.
Phil
Phill is this recommended for all the box variants?
Post #91285 9th Nov 2011 9:29pm
RRPhil
No - just for the GM 'box in the TD6. The ZF 5HP24 & 6HP26 transmissions don't have anything like the same problems.
Phil
Post #91286 9th Nov 2011 9:33pm
T24RES
What if any mileage would you recommend oil changes for the later box? eg-Mine 2008my TDV8
Thanks in advance
Post #91293 9th Nov 2011 9:51pm
RRPhil
@ Johnte
I was wondering about whether your symptoms could be related to the common spring failure in the 2nd clutch accumulator (photos from a 5L40-E that I recently stripped):
but that would really effect the 1-2 upshift rather than the downshift and also wouldn’t explain why it isn’t repeatable once the fluid gets warm.
(Incidentally, if any of you TD6 owners are experiencing harsh 1-2 upshifts, this spring breakage is probably the reason why)
I need to think some more about this one – I’m much more familiar with the ZF transmission than this one I’m afraid.
Phil
Post #91303 9th Nov 2011 10:13pm
RRPhil
@ T24RES
The first 6HP26s appeared in 2001 so there’s 10 years of evidence to confirm that it’s a pretty robust transmission. For that reason I’d normally be tempted to stick with the manufacturer’s recommendation i.e. 100k miles.
However, the high detergent levels in automatic transmission fluid mean that (in my view) you’d be taking a risk of dislodging wear particles from the clutch packs, etc. that had accumulated in all the nooks & crannies of the hydraulic system after such a period of time which could then have a catastrophic impact on the control system (pressure control solenoid valves, spool valves, etc.) if they were flushed through the mechatronic unit by the new fluid. For that reason I’d be tempted to drain & refill at 50k miles.
For the 5HP24 much depends on the condition of the cooling system. We all know about the issues with the bottom of the radiator becoming blocked with sediment and choking the cooling supply to the transmission fluid cooler. The resulting higher temperatures cause the fluid to oxidise much more quickly than ZF had planned for when they quoted ‘filled for life’ (i.e. 100k miles). It’s therefore essential to maintain the health of the cooling system and I’d also recommend changing the fluid at 50k miles. Certainly the fluid should be replaced if the transmission has ever operated in its ‘cooling strategy’ mode i.e. holding on to the lower gears with TRANS OVERHEAT displayed on the instrument panel – in which case the fluid temperature has reached 140 deg. C
A tribologist at Shell told me that at elevated temperatures a fluid’s life is halved for each 10 deg. C rise in its temperature. Pretty alarming Shocked
Phil
Post #91315 9th Nov 2011 10:46pm
Thanks for all the info and guidance RRPhil.
I didn't know what one was either:
A tribologist:
"One who studies or is a specialist in the science of the mechanisms of friction, lubrication, and wear of interacting surfaces that are in relative motion."
Thumbs Up .
Post #91338 10th Nov 2011 1:41am
@RRPhil
Thanks for all you info. I have no issues (touches big bit of wood) but enjoy reading all your gearbox info. You really ar the gearbox king! Would love to get my head round how an auto box works. Not sure if you have the time but if you could put together a basic discription with a few of you quality pics I'm sure it would go down well, as I for one would appreciate what goes on in the box of tricks under the gear leaver a lot more. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #91340 10th Nov 2011 2:27am
I think if you do a quick search on the frenchcarforum or citroenxm forum, dont mean to step on any toes RRphil just thought i could save you a load of time Smile
http://auto.howstuffworks.com/automatic-transmission.htm
Post #91347 10th Nov 2011 9:42am
T24RES
Thanks RRPhil for the comprehensive reply, most informative Thumbs Up
Post #91370 10th Nov 2011 11:34am
