Home > Maintenance & Mods (L322) > TD6 Flat Battery and Clarke Jump Start 4000
I decided to take the plunge and get one of these jump start packs a few weeks back, so I went to Machine Mart and bought the biggest capacity version, the Clarke Jump Start 4000, capable of cranking up to a 6 litre petrol engine or a 4 litre diesel. Splendid.
Low and behold, my dad has a flat battery on his TD6, so I offer to pop over and start it up for him.(Feeling smug)
I follow the instructions, hook it all up, nice and easy and give it a few minutes connected before trying to crank.
Nothing. Shocked
Wait some more.....nothing.
To say I was deeply disappointed is an understatement.
Now, I tried jump starting the car using jump leads from mine, connected up (got sparks so I know its working) and left my car running for about 10 mins to help his battery, then crank it.
Nothing. Shocked
The question here then is this:
Are those jump start packs totally CR@P or is his car just so dead that nothing would crank it unless a new battery is connected up?
The end result is that he has called out LRA at great cost and they will have to make it work. He's had 3 new batteries in 12 months which is clearly not right, but I found out that he doesnt bother locking the car, even at night and I know the ECU's need to be shut down properly to stop the draw on the battery. Couple that with short journeys and I'm not sure its getting enough charging time.
Opinions? Advice? Discovery 4 HSE
Post #91399 10th Nov 2011 12:46pm
In my opinion yes when used on a RR.
They have very small batteries in them and will only start a car if you you can guarantee nothing else on the car is connected and running before the engine starts.
With a RR if you have any door open the current draw is significant before you even turn the key.
Leaving the jumpstart for a few minutes could well have depleted the in-built battery suficiant to make it useless.
I used to use a jumpstart to start a Disco without any bother even in winter but it wouldn't touch my RR.
If you want a proper jump pack you need to spend £4-500 as the pro's use.
A big spare battery is more use.
Post #91403 10th Nov 2011 1:06pm
Not long back I made my battery go flat, I was cleaning it all day and had doors open etc - schoolboy error.
So I called out the AA (very nice man). His jump start pack was a much lower spec than the one I bought after this incident. He said the problem with his, was that its plugged into the van to charge it up but it never gets properly charged like when its plugged into the mains, as its being used during the day and his journeys are short, so you would hope at least, that this Clarke one might work.
I will wait for one more time of using it to see if it works, if not, I'll take it back. Sods law states I wont need it again Discovery 4 HSE
Post #91404 10th Nov 2011 1:14pm
Depends on the Jump start packs …
I have this one although never used on the FF , i use it for the Motorhome that i have and that has a large battery in it and it fire's it up with no problem …. maybe your dad's is goosed
Post #91405 10th Nov 2011 1:15pm
RRRob
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
I am with ick on this. I have one of the Ring 40ah packs and I have jumped the TD6 no problem.
The pack needs to be charged monthly and I suspect a partly discharged pack would struggle to start a large engine.
The pack is 40ah but I believe it has 2 x 20an batteries in it.
All in all an excellent birthday present from the better half Thumbs Up
Post #91409 10th Nov 2011 1:22pm
Fr_Raf
France 2004 Range Rover Vogue 4.4 V8 Java Black
Yesterday morning, at 6 AM, I had to travel by train, and park my car early in the morning in the car park station, but forgot to switch off my lights on my 4.4 V8. At 11 PM when I went back, I only had enough power to open the front door. Fortunately, at this station, they have a jump start. I connected the wires, and try starting the car. It started immediately.
Then, for me, it works
Post #91411 10th Nov 2011 1:32pm
As a small note to add the beginning of this post I hardly ever lock my car and it has never had a flat batterie . 2008 MY Supercharged
Post #91424 10th Nov 2011 2:41pm
The Clarke Jump Start 4000 has the following spec:
Starting Boost 700 Amps
Peak Amps 1500
Max Petrol engine starting size 6000cc
Max Diesel engine starting size 4000cc
I am not an electrician, is this not enough to crank a TD6 or TDV8 more importantly? Discovery 4 HSE
Post #91425 10th Nov 2011 2:43pm
simon1233
Does it not also depend on the amount of discharge in the vehicle's battery?
When my alternator failed the voltage in the battery dropped to 3 volts. The man from landrover assist used 2 booster packs. The first was 'sucked dry' by the RR without even blinking, the second one was used in combination with the jump leads from his discovery. After 20 minutes it had sufficiently charged the car enough to start up...
Slight discharge of the battery (enough to prevent cranking) and these packs will work fine. Substantial discharge of the battery and they are useless (IMHO) Thumbs Up
Post #91434 10th Nov 2011 3:13pm
AAARRRGGGHHHH Banging Head Banging Head Banging Head
No Wonder!
The flippin starter motor was goosed as it turns out! Discovery 4 HSE
Post #91435 10th Nov 2011 3:14pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
On a side note - Shouldn't you connect live to the battery but earth to the bodywork (rather than the battery) Essentially using the battery pack instead of the battery rather than dragging the amps through a dead battery.? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #91437 10th Nov 2011 3:26pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
You would still be connecting to the dead battery and so draining your pack - if you really want to just use the pack, then disconnect the live lead from the battery and connect it to the pack (i.e. pack replaces dead battery) - then as long as it's a HUGE pack which can provide the necessary starting current for the FFRR then you are laughing.
Post #91445 10th Nov 2011 4:02pm
The best thing to do is buy a new battery and keep it trickle charged at home for just such a day!
Would cost about the same as this jumper pack too. Censored Discovery 4 HSE
Post #91448 10th Nov 2011 4:12pm
^^^^^ Thats the best answer. Smile
Post #91450 10th Nov 2011 4:16pm
I have 4 vehicles that all use the same size battery as the FFRR and always have a new spare on the trickle charger
Post #91452 10th Nov 2011 4:17pm
