![]() | Home > Maintenance & Mods (L322) > Rear washer. |
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 746 ![]() ![]() |
Isn't working - where's the jet, I must be missing the obvious as I can't see it anywhere |
It's at the top of the wiper under the brake light , think you will have to make sure the wiper is half way through its cycle and switch the engine off so that the blade wiper arm at sitting exactly in the middle of the screen … ====================================
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
wiki? ... - .- -.
it's not Wiki… it's just not Worki …. |
woki u say? |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
The jet is on the arm spindle end.
Mines like yours Alan it just runs down the rear screen is that how they are supposed to operate or should I be expect more of a squirt like the fronts ? Present :2008 TDV8 HSE
Expect a squirt , something near as the fronts ... ====================================
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3817 ![]() ![]() |
mine just gushes down the screen, and has done so since new - never squirted! |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
I have just recently replaced the non-return valve on the rear washer. It is like new now with a healthy squirt. It was taking forever for the water to come out as it was all running back down the tubes! £2.50 from halfords, and the stealer was wanting £80+ just to investigate.. Previously..
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
That about sums mine up! ![]() Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764 ![]() ![]() ![]() |
Hey Contraband - Would be good to get a description of what you did for others suffering the same common problem.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
I'm going to be interested in a new one way valve |
Sounds like its a female washer jet arrangement! |
