Home > Maintenance & Mods (L322) > Rear upper and lower hub bushes help
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Any advice from anyone how to do these ive had a look at the bushes there straight forward but whats the best way of fitting them in the hub i.e do they press in onto no6 Range Rover
Everyone needs a hobby
Post #91671 11th Nov 2011 5:43pm
You need to mark the top bush bolt with a centre punch as it adjusts the geometry.
Leave the hub assembly in place, the top bushes press out fairly easily, there are a few threads on the forum of how to do them. The bottom bushes are a little more tricky and are tight as hell to remove, I used a 6' steel tube and a big hammer to help mine along.
Replacement is reversal but do get a 4 wheel alignment and geometry check once you have rebuilt it
Post #91760 12th Nov 2011 10:12am
