Home > Technical (L322) > Two issues... |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6349 |
Welcome to the forum.
23rd Apr 2009 6:41pm |
Landrovered Member Since: 06 Apr 2009 Location: GEORGIA Posts: 18 |
Yes I do.
23rd Apr 2009 9:03pm |
Full fat not diet Member Since: 16 Nov 2008 Location: Herts Posts: 1209 |
Welcome to the Forum Landrovered - look forward to your contributions feedback and pics of your car and work etc |
23rd Apr 2009 9:32pm |
skydve1 Member Since: 04 Nov 2011 Location: Virginia Posts: 1 |
I know this is an old thread, but I've just run into this with my 2003HSE. I wanted to see what you finally replaced to get the leak to stop. I was playing with this on the weekend. A friend who works at the local LR dealer told me to pressurize the system to 25psi as they do at the dealer, to make sure it shows every leak. When the system is pressurized, the leak stops at the transmission cooler area. As soon as I bleed off the pressure, coolant comes running out. If I let it drip for a bit with the filler cap on, it creates suction in the system and you can hear a pop from the cap when you take it off. Damndest thing I've seen in awhile! Thanks in advance... -Tommy 2003 HSE , 2001 DII , 1988 RRC, 1988 RRC, 1988 RRC Vogue |
14th Nov 2011 3:19pm |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 |
The mirror issue is easy, on the underside of the mirror housing remove the plastic plug, inside are three torx screws - tighten them up and replace the plug.
14th Nov 2011 4:17pm |
