![]() | Home > Off Topic > wiring for induction hob |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
my the kitchen project is progressing and i will soon need to wire up an induction hob..is there anybody in the 'know' that can advise me whether i can splice into my cooker [30amp ?] cable.. ... - .- -.
so thats both on one cable yes?
Bodsy Member Since: 10 Mar 2011 Location: Shropshire Posts: 45 ![]() ![]() |
They both have their own cable, which then both go to one switch with one cable back to the consumer unit. |
thanks for the info and advice bodsy.. |
Check the ratings on your cooker and hob before doing this. If together they exceed 30 amps then its a no no.
thanks joe..i'll be running a spur from the 'oven' switch and both the oven and hob comes to 27 amps so its within the 30 amp rating ... ... - .- -.
Have you ever seen the flash from a 27 amp blow not forgetting the bang, it makes a heck of a mess |
no, but i've drilled into a live mains cable... |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
BBBBZZZZzzzzzzzzz, FLASH!!! ![]() Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
Well that was a silly thing to do ![]() ![]() |
