Home > Maintenance & Mods (L322) > TD6 Oil Change - Which oil ?
Johnte
I'm going to change the oil on my TD6. On doing a 'search' and a 'wiki' I come up with both a 0w40 and a 5w40 anyone know which is correct?
The reason I'm trying a change, I have what sounds like a sticking tappet.. Sad I'm hoping an oil change will help.
Post #92474 15th Nov 2011 7:41pm
Green
My FFRR handbook says:
Engine oil - Diesel vehicles
Use a 5W/30, 5W/40, 10W/30 or 10W/40 oil meeting specification ACEA: A3 and B3, and having a
viscosity band recommended for the temperature range of your locality.
Engine oil temperature ranges
5W/30 will protect from -30oC to 35oC (-22oF to 95oF).
5W/40 will protect from -30oC to 50oC (-22oF to 95oF).
10W/30 will protect from -10oC to 35oC (14oF to 95oF).
10W/40 will protect from -10oC to 50oC (14oF to 95oF).
Hope this helps.
Post #92481 15th Nov 2011 7:53pm
Use the thinner 0w/40 then
Post #92484 15th Nov 2011 7:57pm
Johnte
What's the disadvantage of using 'thinner' ^^^
Post #92489 15th Nov 2011 8:11pm
The advantage for you is if you have a sticking tappet, then hopefully the thinner oil will get into it and free it off.
Post #92492 15th Nov 2011 8:15pm
Johnte
I can see the advantage, just wondered if there was a disadvantage ?
Post #92498 15th Nov 2011 8:20pm
Not in our climate
Post #92508 15th Nov 2011 8:57pm
Will thinner oil not get past all the seals, scrapper rings etc and burn off quicker? Also, if the engine has done quite a few miles it will be worn and benefit from a slightly less viscose oil. IMO.. Previously..
Post #92511 15th Nov 2011 9:08pm
You need to read this then... Whistle
http://www.fullfatrr.com/forum/topic746.html Discovery 4 HSE
1993 90 Tdi
Post #92514 15th Nov 2011 9:11pm
Modern engines don't suffer leaks the same as their older counterparts did. I wouldn't expect 0w/40 to leak out anywhere. As to the viscosity on older engines, it would need to be well worn already to do any harm
Post #92515 15th Nov 2011 9:13pm
