![]() | Home > General > To al those who power wash their cars........DON'T!! |
| M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325
Tin of electrical contact cleaner, some cotton buds, some beer and a free hour or so, that should sort it. 2006 Mercedes CLS
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880
so that's why we couldn't clear them faults james |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
Thanks guys. Have noticed there is also a space in the plastic housing under where the CANBUS cable goes into the unit! I would have thought a rubber grommet would have been more sensible for such an important piece of kit!
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
Have you checked in RAVE how to do it?
| Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543
Agree with above post. Some years ago I pressure washed the engine bay of my old Discovery. I thought what harm could it do to an old diesel engine? The result was a knackered alternator as water must have penetrated into the electrics. No longer FF owner but still interested. Present car Jaguar XE
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
Thats interesting, I used to pressure wash the engine bay on my Discovery a couple of times a year and never had any bother, Not sure whether I would risk it on a RR, time will tell. |
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1563
Yes - I know exactly the problem the OP has.
Yes, get a flat bladed screw driver. on the loom side of the connection, there is a sliding holder which opens by pulling the slider towards the engine. Stick the screwdriver in the end of the slider nearest the engine and lever the slider towards the engine. This should move the slider over and at the time push the connection open, once its fully moved over, the connector should pull off as normal. the same is true putting it back on, pushing the slider away from the engine will pull the connection closed. You'll see what I mean when you try it. The slider levers the thing on and off. V8 or else ... |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
I set the pressure washer to 130'c and held it back a metre or two so it was a pure stream of steam and only after the engine had been running a while to make sure it was hot enough to boil it off while i washed the rest of the car. |
I've always periodically sprayed all the electrical connectors I can find in the engine bay with WD40, definitely stops the corrosion in them.
Thanks Fisha, got the top off ok.
did you do the steering wheels full lock left ,then full lock right after the battery re-fit james...
| cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556
When i cleaned my engine bay i sprayed the autoglym engine spray everywhere left it 30mins and then set the hose to a fine spray rinsed it off and it looked like new (touch wood no probs) |
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
In Switzerland they want you to jet wash the engine before the MOT. I never have and have always passed. I think that's because in my Kanton they're not tw@'s. But it's a stupid thing to do unless you've had an oil leak. |
| All times are GMT |
