Home > Technical (L322) > TV Tuner Install
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
TV Tuner Install
I've done a search so I'm guessing it's a esy as it looked
I've had a quick look this morning before going to work to c what I had to do to my hybrid tuner
Is it really as simple as undoing the 10mm at the top unplugging the wires and pullin the old unit out and just sliding the new one in??
Thanks
Neil
Post #92323 15th Nov 2011 11:31am
Knips
United Kingdom 2017 Range Rover Vogue SE SDV8 Santorini Black
On mine...
The Tuner sits in a cradle and with the cables on top it can be difficult to relocate. However judicious use of a mirror and torch will allow you to observe the location of the lugs on the bottom cradle. There is no flex in the bottom cradle due to its thickness and form.
Take a photo of the location and level of the old tuner before removing it. I had to wriggle the tuner to get the cradle to release its grip and like everything FFRR you have to use a bit more force than you might wish. Make sure the wiring bunch on the top of the tuner is pulled clear before removing, an assistant is useful.
Suggest you try the new tuner before fitting in the cradle by connecting the connectors and antenna pair and checking correct operation on power up. The connectors will reach if you lean the new tuner against the wiring at the front of the AV "cubby hole"
Mine fouled slightly on the Sat Nav comp when I tried to remove it and some wires (a brown bunch) had been fed through the LHS of the tuner cradle. So I undid the bolt holding the rear LHS of the cradle and the bolt locating the front RHS to give me enough "flex" to re-locate the new tuner and to move the brown wire bunch outside of the cradle in the correct position.
I had a blank screen after initially powering up (no comp/logo). A squirt of connector cleaner (Maplins I think) and relocation of the plugs got it going well.
Knips
Post #92346 15th Nov 2011 1:27pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Re: TV Tuner Install
Thanks
Neil
Or the short answer is YES Laughing Thumbs Up
Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #92522 15th Nov 2011 9:31pm
Knips
@Andy
May I refer the honourable gentleman to my previous response as the even shorter answer is .... no..... Laughing
Post #92527 15th Nov 2011 9:42pm
cliffy
It was easy im in shock Shocked
Big shout out to Andy for all the advice and help Thumbs Up Bow down , the tuner works great and the TV in motion lead is cracking to
Ive put my AV input lead in as well with the reverse Camera input to
So now i need to get a DVD player and a rear camera loving the Vogue even more now this car gets better and better
thanks again guys for all input Cool
Post #93215 18th Nov 2011 7:20pm
