![]() | Home > General > Self-Levelling Suspension |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35820 ![]() ![]() |
have not all the ranges have self levelling suspension? |
Yep |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 ![]() ![]() |
1993 Hth David |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 793 ![]() ![]() ![]() |
Thanks guys |
maybe but i'm pretty sure the s/c has a stiffer setup ... |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
10MY saw the introduction of Adaptive Dynamics which stiffened up the body shell and reduces roll on bends ALOT. Self levelling has been standard throughout the L322 and, as others have said, much much earlier in terms of Range Rover. |
Thanks Johnson - my incorrect use of terminology.
The S/C already has a pretty stiff suspension and corners quite flat. But I also know that the LR engineers do a lot of tweeking and tuning on their cars so the newer versions will be better. The question is by how much of a margin. A FFRR will never be cornering like a Ferrari/Aston/Lambo etc. although it is quite impressive what they have done on the S/C.
It's a very good system and I can, and do, corner quickly. You can feel a slight roll but it doesn't throw you out your seat! As others have said, it's never going to work like a BMW round corners. There are so many more benefits to 10MY+ so if you can stretch to one, do. |
Thanks Johnson
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
Adaptive Dynamics has made a massive diff to the car Far to many gone... |
No probs. Should definitely go for a 4.4TDV8!! |
