![]() | Home > Maintenance & Mods (L322) > Mirror approach lamps - led bulbs |
have a read through this … might help
yep |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Or, you might have both of them in the wrong way round. LEDs are directional. I replaced loads of filament bulbs on my D3 with LEDs, no issue at all. The indicators DO need resistors though. Graham
Blackbird51 Member Since: 22 Sep 2011 Location: Portadown Posts: 39 ![]() ![]() ![]() |
Cheers for fast responses LEDs are fitted correctly. Reckon it must be the resistor issue. Now to find some suitable led bulbs. Will post result. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35800 ![]() ![]() |
its the same with the map reading lights, normal leds dont work.. |
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
This would explain that problem then! |
Tried 4smd LEDs with built in resistor. Things are improving but only just!! Both LEDs illuminate but only for 2-3 seconds. No fade. Does anyone know the resistance required to get correct operation? |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
Seems to be an awful lot of effort just to put some LEDs in. I'd have thought you're better off with normal bulbs, as LEDs are all pretty directional and you want the light to spread out a bit more for the approach light to function suitably. |
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 ![]() ![]() ![]() |
Are these LED bulbs not illegal for use on the outside of a car? |
leds are ok to use..
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
When I changed all my interior lights for LED lights I cut and soldered the live wire to the mirror puddle lamps into the lower door panel illumination circuit, so they work without the fault and a bonus is, they stay on with the interior lights for longer!
edit on my previous post..
