Home > Technical (L322) > Mirrors Go Mad When In Reverse
m90got
United Kingdom 2003 Range Rover HSE Td6 Alveston Red
After collecting my 2003 ffrr this weekend i have had loads of trying to find out how everything works,still learning lol
one thing is whenever i put her in reverse both wing mirrors seem to have a fit and move all over so i have to adjust them before i can move,
can some one please tell me how to stop this happening
Cheers Paul. Thumbs Up Current Stable:
Range Rover 2003 TD6 HSE Alveston Red, Sand Leather
Ford Focus C-Max silver 2003
V/W transporter Blue 1995
Yamaha XJR1300 Yellow 2002
Kawasaki ZX7R Green 1998
Honda CBR 600 Black 1998
Yamaha RD125LC Mk1 Red 1986
Yamaha RD125LC Mk1 Blue 1986
Post #93478 21st Nov 2011 9:19am
the nearside will drop its angle of view to help reversing if you have the 'side' selector towards the off side, but its weird that both mirrors having a fit...
there are micro switchs inside the mirror units that do get stuck causing problems ..did you pressure wash the range ? maybe water has got into them..
Post #93482 21st Nov 2011 9:38am
m90got
No i havent power washed it i have been and tryed it again and yes it was only the n/s one that moved,
they must have been moving together when i was using different keys to open it,
i have still to learn how to properly program everything yet happy times lol Thumbs Up Current Stable:
Post #93494 21st Nov 2011 10:07am
m90got
It gets better lol
now when i press the button to unlock it, all the doors apart from the drivers door unlock and i have to unlock the drivers door with the key
note to self must get four year old daughter to teach me how to use it lol Rolling with laughter Current Stable:
Post #93530 21st Nov 2011 1:58pm
pretlove
oh the joy of range rover ownership Rolling with laughter "RANGEISM WILL NOT BE TOLERATED"
Post #93544 21st Nov 2011 2:56pm
Lookers Park Royal
m90got,
I can't help with the door situation, but may be able to help with the mirrors.
Start up the car and get the seats and mirrors into the position that you want and then memorise the position on number one by holding the memory button on the side of the seat and then pressing number one at the same time.
Once you have done this, put the vehicle into reverse and let the mirrors move and wait until they stop. Once they have stopped and whilst the vehicle is still in reverse, adjust the mirrors to where you would like them to be when you are reversing. Then repeat the memory save process above by pressing the memory button and then number one at the same time (press mem first and whilst pressed press number one).
This should memorise the mirror positions for drive and reverse, and fingers crossed the mirrors will only move to the position that you have saved in the reverse position.
I'd be interested to hear if this cures the problem.
James Thumbs Up
PS If you need to use both keys for yourself then you will need to repeat this process again with the other key and make sure you lock with the first key after the first 'save' then unlock with the second key before you repeat the process the second time. Or alternatively just use the one key.
Post #93605 21st Nov 2011 6:47pm
didnt know you memorise the reverse mirror position.. Thumbs Up
Post #93606 21st Nov 2011 7:00pm
Lookers Park Royal
Note - This will only work in the passenger mirror.
James Thumbs Up
Post #93630 21st Nov 2011 9:08pm
T24RES
me neither Scarey, i'll try that for the reverse mirror. Thumbs Up
Post #93658 21st Nov 2011 11:23pm
Vogue
me neither! and after all that faffing around on several L322's with the passenger mirror for the last 5 years
Post #93704 22nd Nov 2011 11:33am
Vogue
tried this on mine today, doesn't work, I did exactly as per Dan's instructions, but I cannot move the mirror once it has dropped to the reverse kerb level view - the mirror adjust button has absolutely no effect when the mirror is in the dropped position.
Post #94056 23rd Nov 2011 10:52pm
m90got
i followed the advice from James and it all worked even the mirror, it only works after you do the memory thing then have the mirror button acros to the drivers side Current Stable:
Post #94058 23rd Nov 2011 10:56pm
Vogue
thanks, I'll try it again, trouble was when the mirror dropped and I moved the button over to drivers side it came back up again...
maybe I missed something
Post #94059 23rd Nov 2011 11:02pm
