Home > Maintenance & Mods (L322) > Nav Computer repair
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Nav Computer repair
Just wanted to ask before I do open heart surgery on my nav computer - any nasties in the strip down I should be aware of?
If you are wondering why I am doing this - the nav computer has for a while been hit and miss as to finding any satellites or not. Recently it has got worse. The Nav unit seems to function and the map is fine etc (yes I have tried an external sat aerial) so I am thinking possible damp (no sign anywhere else) or dry joints etc. "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #93509 21st Nov 2011 10:52am
dont think its been done before, but good luck..
Post #93522 21st Nov 2011 12:26pm
MrP
First time for everything - I will try to remember to take photo's then. "On first name terms with my local Dealer......now."
Post #93523 21st Nov 2011 12:38pm
daveo
Yes had my one apart as it would not eject the disc, but since then upgraded to the mk4 dvd unit. not much to them, main drive unit and main pcb at the base with aux pcb at the back and side. yes water damage can do some strange things so have a good look for signs of corrosion on the board it could be an easy fix
but you have noting to lose. V8 facelift Range Rover Autobiography 22" wheels.
Post #93524 21st Nov 2011 12:46pm
sorry dave , forgot about you.. Embarassed
Post #93525 21st Nov 2011 12:56pm
MrP
Ok - has to be one of the easiest jobs. MKIV unit removed and top and bottom panels unclipped to reveal ..... perfectly dry normal looking item.
Gave it a quick blast with air and checked for unseated ribbon connectors etc - reassembled and put back in car.
Nav boots up and sees satellites - no guarantee that it is fixed as it could just be having a good day but time will tell. "On first name terms with my local Dealer......now."
Post #93534 21st Nov 2011 2:25pm
sounds like a loose connection then.. Thumbs Up
Post #93538 21st Nov 2011 2:30pm
