Home > Technical (L322) > Loss of power and missfire on SC
NKSC
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
Driving to work this morning I experienced a total loss of power from my FF. Happily cruising at about 75mph and suddenly dropped back to 25mph. I managed to get off the dual caraigeway where it completely cut out. I restarted it and it was running badly so i phoned the RAC. Turned out to be only firing on 7. He had a look over it and restarted it a few times and it eventually sterted firing on all 8. His code reader came up with the following codes:
P0301
P0316
P0087
P0088
As it was low on fuel I went to the filling station a few miles away and filled her up and she seems to be running ok now. He suggested that as the fuel was low some air may have got into the fuel system and caused the missfire. The fuel gauge was giving a range of 65 miles so about 4 gallons.
I was wondering if anyone could tell me what the codes are and if this is a plausible reason. I'm hoping its nothing more sinister!
Thanks
Nick
Post #94139 24th Nov 2011 1:53pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
I had a similar though less severe experience recently whilst very low on fuel, just power loss on motorway, no eml, and was fine after I filled up! Thumbs Up 2012 SDV8 Vogue SE
Post #94141 24th Nov 2011 1:59pm
My M5 was continually going into limp home mode and being trailered back to the dealer, eventually it was diagnosed as being the MAF Mass Airflow sensors, in others words the oxygen sensors, they were replaced and it was like getting a different car in terms of the power, it released the full might of the 5.0 V8 which had been running poorly before.
Have faith! Discovery 4 HSE
1993 90 Tdi
Post #94142 24th Nov 2011 2:04pm
NKSC
The EML came on when i restarted and also a message saying the engine was running on reduced power. After filling up, the EML had gone off and there were no warning messages.
Post #94144 24th Nov 2011 2:20pm
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
This?
http://www.fullfatrr.com/forum/topic7108.html
HTH
David
Post #94145 24th Nov 2011 2:26pm
Daveo might be able to tell you what the codes actually mean Discovery 4 HSE
1993 90 Tdi
Post #94231 24th Nov 2011 8:43pm
NKSC
Thanks for the info guys. Thumbs Up
It seems similar to the problem Dan had in his. I have done about 100 miles since and have had no problems with the tank full. I will run the fuel low again next week and see what happens.
Post #94343 25th Nov 2011 11:02am
here you go: from http://www.eobd2.eu/DTCL.asp
P0301 Generic Cylinder 1 Misfire Detected
P0316 Generic Misfire Detected On Startup (First 1000 Revolutions)
P0087 Generic Fuel Rail/System Pressure - Too Low
P0088 Generic Fuel Rail/System Pressure - Too High Discovery 4 HSE
1993 90 Tdi
Post #94353 25th Nov 2011 11:26am
You VERY probably have a dodgy fuel pump as those are the exact 4.2 SC symptoms I suffered and Dan suffered when the fuel pump cannot "Jet" fuel from one side of the bottom of the tank to the other! Normally happens with about 65 miles to empty indicated.....
You have fuel in the right side of tank but pump can use it.
The error codes are as above.......
You need a new pump so buy one fron Dan at Duckworths and get it fitted at an Indy. Total cost about £400 but TOTAL fix. Thumbs Up
PS: It a very common problem on the SC but seemingly not on other models.
Post #94379 25th Nov 2011 1:07pm
Better still, get the supplying garage to fix it for free! Discovery 4 HSE
1993 90 Tdi
Post #94381 25th Nov 2011 1:31pm
NKSC
Thanks Gary. I will return it to the garage next week as its still under warranty. Thumbs Up
Post #94384 25th Nov 2011 1:36pm
Strange how this has happened Nick that SC never gave me any bother fuel pump wise .... Shocked and if Adam passed you on the supplying info I sent you can see there was no expense spared on any repairs needing done ...... And all done at Dealerships ====================================
Post #94387 25th Nov 2011 1:59pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I'm saying nothing as mine is due a service and is looking at me funny.
Shocked Laughing
Post #94388 25th Nov 2011 2:01pm
Mick we have a theory that involves ESP and a pressure washer.... Discovery 4 HSE
1993 90 Tdi
Post #94399 25th Nov 2011 2:59pm
NKSC
Mick - As Adam says its slightly suspicious that they had the car for over a week to fix the cold start squeak and reverse camera, and the day after I pick it up I had this problem.
Will be putting 450 miles on her over the weekend so will see how we get on. (will be keeping the tank well topped up though!)
Post #94405 25th Nov 2011 3:54pm
