![]() | Home > Maintenance & Mods (L322) > Average life of HIDs ? |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 ![]() ![]() ![]() |
I was told once by local LR Service Dept they are supposed to have an expected life span of 15000hrs??? - im not sure how correct this information might be |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 ![]() ![]() ![]() |
mine keep flickering too |
^^^ Sorry to hear that Simon. As I mentioned above - its most likely the flickering lights will be caused by your headlamp ballast resistor packs failing and not the actual bulbs themselves.
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
No flickering (touch wood) and I'm going to hold off replacing the bulbs for the moment - but thanks for the offer. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35832 ![]() ![]() |
VV ,they do seem to do that, i replaced mine with cheapo 6000k bulbs of ebay and the difference was dramatic...much brighter and whiter.. |
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 ![]() ![]() |
The bulbs drop in output and go pink when they fail - the ballast apparently affects the shutter that sits over the bulb and drops when you select high beam.
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
You can get both the ballast and the ignitors seprately.
