![]() | Home > General > Bad Wind Noise ? Top of dash ? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7933 ![]() ![]() ![]() |
Not sure if any of you can help here.
Try this,
stephenmitchell Member Since: 04 Nov 2011 Location: truro Posts: 13 ![]() ![]() ![]() |
The problem could a badly fitted replacement windscreen? |
Thanks gents.
Well. half way through the rather "windy" 250 mile M1 trip yesterday, I had a quick look under the bonnet at a services. Couldn't see anything obvious - there was no cover/soundproofing near the intake on the underside of the bonnet, so you can see all the washer fluid pipes etc. Had a quick look on the internet and it seems there may not be one there anyway.
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 ![]() ![]() ![]() |
I had this - it was the screen scuttle trim - the bit of black plastic that runs the length of the screen
Warped with age !! I know that feeling well...........
Well, many thanks.
I drove around for a couple of weeks with a big strip of silver gaffa tape on the screen/scuttle panel edge ...it did the trick until the new bit arrived but looked a bit naff |
was the new part the complete plastic scuttle or just the rubber seal between it and the screen ?
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 ![]() ![]() |
Too many baked beans?! 2005 L322 Vogue Gold gone
AndrewT Member Since: 20 May 2011 Location: Auckland Posts: 97 ![]() ![]() ![]() |
I had the same problem with mine but fixed it without any tape.
complete plastic scuttle, so you have to take wipers off to fit cheers bogie |
Many thanks.
