Home > Technical (L322) > 2006 Vogue TDV8 - shakes on idle
WAZZY786
United Kingdom 2006 Range Rover Vogue TDV8 Stornoway Grey
Hi notice sometimes when car is at traffic lights (foot on brake) the car can shake slighlty. Not much but can be annoying - anyone help?
Post #94604 26th Nov 2011 3:48pm
Put it into neutral Thumbs Up
Post #94609 26th Nov 2011 3:59pm
trafpol
United Kingdom 2006 Range Rover Autobiography Td6 Buckingham Blue
Do you have bigger wheels on it from standard ones? Shocked 2006 MY Autobiography. With 'toys'
Honda ST1300 Pan European
Gone
Jaguar 3.0 SE X Type
Honda CBR1100XX Blackbird
TJF by the way for anyone who knows what that means.
Post #94611 26th Nov 2011 4:02pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Had exactly the same on my TD6 but the previous owner had put 20" wheels on it. Not recommended by LR for that very reason.
I put back a set of 19s and it's almost gone now. LR suggest 18s but I think they look a bit small and I'm happy to live with the slight vibration.
You could of course out it in neutral as suggested as it does remove the problem. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #94654 26th Nov 2011 9:35pm
WAZZY786
No it's just got the normal alloys on - i'm looking for bigger ones though Very Happy lol putting in neutral seemed to do the trick!
Post #94659 26th Nov 2011 9:55pm
supershuttle
So does mine, slight increase in revs and everythings fine - I'm not convinced there is a problem. Neutral , change wheel size none of it works for me - it's just a vibration at sub 1000 revs. Geoff
Post #94668 26th Nov 2011 10:23pm
comports
If you have standard wheels then maybe check your tyre pressures. They can make a big difference if not inflated correctly. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #94673 26th Nov 2011 10:37pm
