![]() | Home > Technical (L322) > Battery drain...? related to alarm & FBH problems? |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Well, been a good day so far. Not. |
SAppie Member Since: 08 Feb 2010 Location: Berkshire Posts: 159 ![]() ![]() |
I think that ctek make the best technologically up to date battery charges, this one is fantastic:
Right, thanks. If it is shot I'll get a new one fitted on Weds whilst it's in having the alarm reset...
I use the FBH daily these days, and no issues at all. In the past , when I had the suspect battery, If id use the FBH id end with a flat battery.
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
Just to second sAppie's recommendation re Ctek MXS7 battery charger.
Thanks for the charger tips |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6826 ![]() ![]() ![]() |
It's a tough call, £100+ for a charger that might not charge a duff battery, so another £100+ on a new battery at that point, or £100+ on a new battery with no real need for a charger! |
Well, yes. I already thought of that but I've got a D3 too... so it's £50 per car. Graham
I would say the new battery may be the priority with the charger next to keep the battery in good nick over the long run, assuming there are no current leaks anywhere. 2012 5.0L S/C
Well, after about 7 hours on charge it fired first time. Phew. |
