Home > General > MY2012 FBH Cycle time
Page 2 of 3 <123>
Rolo
United Kingdom 2012 Range Rover Vogue SE TDV8 Orkney Grey
OK, a quick update - managed to try it out on a full cycle this morning & definately NOT 30 mins !
I reckon about 15 to 20. I can't be entirely accurate because whilst the little green light on the remote kept on flashing past 30 mins, after about 22 mins I checked the car and the heater was off. I was presuming the light on the remote would turn off when the heater had, but it just kept on flashing !
Luke warm inside. Am I dissapointed ? Not sure to be honest, if everyone says it should be at full heat & toasty inside then yes it's poor, But if it's just to get a bit of warmth in before driving off on a frosty morning then it does work and do the job. After driving for 2 to 3 minutes, the cabin was then pretty much at full heat, whereas normally it takes at least 6 to 8 mins to heat up from cold.
If it was an option, then I wouldn't have bothered unless it was only an extra £100 or something, but it's standard on the diesel. I wouldn't bother to add it to the petrol given the choice.
As I garage mine I'll hardly use it, but will be interesting to try it out during the snowy season if lft outside.
Anyway, hope that confirms for you Rambles. Thumbs Up
ps. mine is a 2012Model Year version built September 2011.
Post #92602 16th Nov 2011 10:06am
roverron
Belgium 2012 Range Rover Autobiography TDV8 Ipanema Sand
Stealer told me today they could not increase the active period= éo minutes. Censored ! RR 2012MY TDV8 AB ipanema sand
RR 2004 TD6 sold now
Post #92702 16th Nov 2011 7:13pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Rolo
Thanks for info.....i guess the real test comes when winter proper hits.
Will the 17 minutes or 20 ish be sufficient to clear the windscreen?
I suspect the answer will be "no", and the complaints / questions will start coming into LR
Post #92769 16th Nov 2011 11:56pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
I just had the AGM battery and software update done to my MY11 and the time is now 20 mins, if you go into the timed climate screen on mine it now shows 20 mins instead of 30. 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #94936 28th Nov 2011 5:44pm
Rambles
Jez
Thanks for that...very helpful.
My MY11 has apparently had all the software upgrades, and it still shows 30 minutes on the timed climate control screen....so perhaps it has not had them all.
And as for the 17 minutes....the FBH couldn't clear the frost off my windscreen this morning. Just a couple of clear spots at the base of the windscreen. My "old" MY10 would have laughed at this weather and completely cleared the screen.
Post #94947 28th Nov 2011 7:09pm
jez000
If it helps rambles I had two updates done, they were campaigns Q142 and Q137. One was to replace the battery with the AGM one and the second was the software update including the changes to the FBH timing. I am waiting for a new Telestart box to arrive at the dealer but I dont think that will effect the timings. 2021 P400 Silicon Silver AB
Post #94949 28th Nov 2011 7:19pm
Rambles
that is helpful, many thanks
Post #94952 28th Nov 2011 7:46pm
Unless the heater is greatly more efficient than those fitted to older FFRR, 17minutes will not suffice.
After 25minutes this morning my car was lovely and HOT inside, so much so that cranking the dual climate upto 27' each side the system didn't use full fan speed but only just over half to maintain the heat Smile
If LR are going to insist on 17minutes as their burn cycle then something is wrong and its their system, not the webasto causing it and they need to work it out properly and set a few guys onto it. Bodging a fix out to reduce the burn time is not a fix, more like a cheap plaster on a bullet wound!
If anything the newer car should be more power saving on the built in electronics and thus consume LESS power and be able to have a longer burn cycle..
Wonder how much LR would pay someone to sort this out for them as they are hiring now for some quality engineers for electronics and info/media systems and so forth Smile (£35-50k IIRC)
Post #94957 28th Nov 2011 9:23pm
Rambles
I agree 17 minutes is not enough. But I am struggling in my letters to LR to make them accept it is not enough.
Any suggestions for a convincing argument?
Post #95006 29th Nov 2011 7:38am
Quote:
Dear JLR/engineer apprenticeship ltd,
I paid £70k+ for a new FFRR.
Another person down the street paid £12k for his 6yr old model.
he can get into his in the morning, be perfectly warmed and not have to worry about the battery being flat despite it being an older style battery and smaller than designed for(90ah CCA instead of 110ah!)
his runs for a full 30minutes if required and is VERY warm inside.
Mine runs for 17minutes and cuts out. It doesn't even convey that its cut out to the remote i use to turn it on as well.
i go out to the car after its 17minute burn and its freezing inside still.
if you want someone to fix it i suggest you employ the man with the £12k FFRR as he seems to have a better understanding of the system than your engineers with their bodged 17minute fix 'band aid' solution.
Yours Sincereley,
Rambles
I reckon that could do it Very Happy
Post #95007 29th Nov 2011 8:09am
Tomw2000
2011 Range Rover Vogue TDV8 Java Black
Loving that. Should deffo be sent.
Post #95161 29th Nov 2011 8:15pm
Rolo
Update
OK, so mine must have a mind of it's own, or perhaps the temp was reached so shut off early before, because this morning she was on for a full 30 minutes !
Post #102376 19th Jan 2012 9:51am
Rambles
So just back from the dealer.
My MY11 now has a level battery management system. This ensures the battery is kept topped up by the charging system, rather than being allowed to drop as it used to before the charging system kicked in under the "old" "intelligent" system.
I also had a defective battery...which although the local garage equipement said it was ok, the specialist equipment brought down by LR said it was defective.
So when testing it this morning...it did the 17 / 18 minutes that is now the new cycle time on the MY11 Vogue SE which have had the upgrade, or the MY12s straight out of the factory. (According to LR...)
Those MY11s which have not yet been done might do more than 17/18 minutes, but those cars are at risk of not starting due to having a flat battery.
Post #104047 28th Jan 2012 8:36am
Good update Rambles Smile
How warm was the car after 17minutes?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #104050 28th Jan 2012 8:44am
Rambles
not freezing.....but still chilly.
not "comfortable" as described in the handbook which you would get after 30 minutes...the cabin is really too big to make comfortable in only 17 minutes - IMHO.
Post #104092 28th Jan 2012 2:17pm
Page 2 of 3 <123>
