Home > Maintenance & Mods (L322) > Td6 Thermostat (Now sorted)
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Anyone had the thermostat fail, like over night?
My car does not get out of the blue, and at this time of year no heat is produced.
It used to run half way up the gauge and heater was toasty.
Post #93890 23rd Nov 2011 12:02pm
Mine has just gone too, although I do get out of the blue and if stuck in traffic will settle at 12 o'clock. But go down a long hill and it'll cool to @ 10 o'clock.
Planning to swap it out at the weekend so watch out for photo howto early next week (assuming I don't hit any snags.)
To be on the safe side, just check your coolant... Whistle .
Post #94082 24th Nov 2011 2:52am
Richcl
Look forward to result/pics.
I looked on RAVE, looks quite involved Confused
Smile
Post #94106 24th Nov 2011 10:22am
Well, fought my way through to the thermostat, thwarted by the torx bolts on the housing so off to buy tools tomorrow. Uploaded lots of pictures to gallery. Should have it all back together tomorrow and then the write up. .
Post #94640 26th Nov 2011 8:17pm
Howto now up on the wiki Richcl Smile .
Post #95387 30th Nov 2011 10:03pm
Richcl
Cheers, I've had a look. Very Happy
Will have to put a few days aside to do it, the weathers getting colder and my car is freezing!
Post #95389 30th Nov 2011 10:18pm
Oh, I got the thermostat from Foundry 4x4 off the bay @ £25 + VAT ( LR price @ £41+ VAT unless duckworths dan can do better) .
Post #95426 1st Dec 2011 7:23am
duckworthparts
Site Sponsor
£39inc vat for Gen LR
£29inc vat for non gen You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #95430 1st Dec 2011 9:27am
........and free delivery. Thumbs Up
Post #95431 1st Dec 2011 9:34am
Richcl
Update-
Replaced main thermostat (thanks Joe90 Smile ) but car still runs cold.... So after a bit of research found out that their is another thermostat for the EGR cooler, so changed that too; still no joy Sad
I'm at the moment running with no viscous fan fitted and the radiator grill partially blocked off, and still it will not get out of the blue on the gauge.
I did 15 miles on the motorway yesterday and even that did not increase the temperature...
Two things happened to my car that either one could have affected the temperature, I had the EGR valve removed and a oil cooler for the gearbox added, replacing the existing engine mounted cooler.
So either now that the EGR is blocked off, no hot exhaust gases are flowing through the EGR cooler, therefore not heating the engine coolant, or the original gearbox cooler is a kind of heat exchanger and actually helps warm the engine coolant up, so removing has stopped the engine coolant warming up.
My car up to the piont of the above two modifacations being carried out (they were done at the same time) ran smack dead centre of the temperature gauge, and had a toasty heater, returned better mpg.
The mpg has suffered by about 4 mpg, so really would like to get to the bottom of this. Confused
Post #106059 8th Feb 2012 8:00am
when i blanked my egr off , it didnt affect the temperature gauge which still goes to the centre of the gauge..
either its the oil cooler or you dis-lodged something whilst doing these jobs..
btw , i suppose the engine still warms up then.. ... - .- -.
Post #106064 8th Feb 2012 8:57am
Have you considered the FBH has stopped working, diesel engines on there own take a long time to warm up when it's this cold.
Post #106083 8th Feb 2012 10:34am
should have got to a working temperature after a 15 mile drive though.... ... - .- -.
Post #106085 8th Feb 2012 10:41am
Could it be a faulty sender unit and the gauge is reading low.
Have you checked the temperature using the Hidden menu
Post #106089 8th Feb 2012 11:03am
Richcl
Scarey, the engine does not warm up, stays in the blue with little or no heater output.
FBH has never worked (another job to do...)
One plus point is I now have a straight six growl from the engine, the viscous fan removed makes the engine sound very nice Cool
Still want a heater though! Sad
Post #106125 8th Feb 2012 5:06pm
