Home > Technical (L322) > 50 CAN bus error
Dolphinboy
50 CAN bus error
Have had my 2004 4.4 petrol in to garage and managed to clear all previous faults except for 50 CAN BUS which is stopping the HDC/ABS/EAS from re-setting. Can't put my new alloys/tyres on as can't lock suspension to raise car.
Anyone got any thoughts on the cause? It is obviously electrical as when the ignition died for a day or two last week, sparks flew from the Neg pole on Battery when failing to start, indicating a short of some sort. Thought I had cured it with insulating tape around the neg wire.
THe three things I can think of causing the CAN BUS failure to re-set are:
1. ABS cable to sensor on left being worn/bare from rubbing
2. ABS module shorting or bad connection. Have checked the pins/connector - it is clear of corrosion adn sprayed electrolux oil onto connector. Could it be within the main ABS module housing (see http://www.fullfatrr.com/forum/topic2582.h...abs+module )
3. Short circuit to +ve. There is apparently a fuse or connector close to the battery pole end of the Pos wire? Sporadic Fault?
Anyone any other thoughts? THe automotive sparky has had a go adn can't get it to clear either. Sad
Post #95497 1st Dec 2011 2:29pm
cant help you with the error james but you can jack up without locking the suspension, i've done it loads of times.
Post #95503 1st Dec 2011 2:37pm
Dolphinboy
I thought you can't raise the car on an all point lift/hoist without first putting it into off-road mode in order to stop it throwing a fault?
Can I change each individual wheel then on the ordinary jack without altering the height?
Ps when I switch off and get out of the car, the EAS injects a bit of air into each strut and raises the car slightly. Is that normal or the sign of stg wrong? My TD6 doesn't do it!
Post #95677 1st Dec 2011 11:38pm
You can jack it up and change individual wheels without locking the suspension... I do it all the time, when you restart the engine the suspension will level itself...
Craig Thumbs Up
Post #95680 1st Dec 2011 11:46pm
i assumed you were jacking one or two wheels at one time james not the whole thing [like to see your garage Laughing ]..
Post #95691 2nd Dec 2011 8:51am
Dolphinboy
No Stan, was getting my new discs and brakes put on my TD6 and asked if they wouldn't mind swapping the V8 wheels for a consideration. But they have a hoist which should make it quicker adn simpler. sadly not to be so it's a couple of hours grunting adn strianing this weekend.
Still no solution to the 50 CAN bus error. Sad
Car drives lovely though! Smile
Post #95723 2nd Dec 2011 12:13pm
if the car drives ok , i wouldnt worry about it to much mate.. Thumbs Up
Post #95727 2nd Dec 2011 12:20pm
Something crossed my mind when I read your last post.
I think it's possible you may have a bad connection on your -ve battery terminal.
I would be inclined to remove the earth cable from the battery post, clean the post with emery to shiny metal, the same with the inside of the earth cable clamp, coat the post and the inside of the clamp with vaseline and re-assemble.
May not solve your problem but it won't do any harm.
Also could do the same to where the earth cable bolts to the body.
Your car is getting to an age when it pays to clean all the earth points you come across, removing any surface corrosion on the contact surfaces.
Can definitely stop problems arising.
Post #95735 2nd Dec 2011 1:54pm
Danwilderspin
Did you ever fix this? Did it flash up air suspension inactive sometimes?
Post #425803 31st Jan 2017 10:04pm
Dolphinboy
Dan, the prob was the neg pole and connecting wire not being tight enough fit - so a bump could lose you power momentarily. All good since tightening up the battery connections. (Think that was the cause but it was 5 years ago!)
Post #425816 31st Jan 2017 11:47pm
