Home > General > Spare Wheel
Page 2 of 3 <123>
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Nah, it's not that difficult to do. I recently bought a new set of wheels and fitted them all with the standard jack (which is 8 years old). Provided you use the jack correctly it is well up to the job, just make sure the thread is nice and clean. Whole job took me about half an hour. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #95668 1st Dec 2011 11:02pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
Sorry but I would have to say that the standard jack is crap. There have been a number of warnings on another forum about the FF jack. May be O'k on concrete but thats all. Good trolley jack is the way to go. I carry a hydrolic bottle jack in mine.
Gary
Post #95686 2nd Dec 2011 3:13am
RR8701
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
interesting that you mention that, you mean something like this
http://www.amazon.co.uk/dp/B0015NSUBC/ref=...B0015NSUBC
Post #95756 2nd Dec 2011 4:32pm
thats what i got , not that make but similar...stored in the right rear cubby hole ..
Post #95760 2nd Dec 2011 4:53pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Is the lift sufficient to get the wheel off the ground? Quite a lot of wheel travel to deal with. Is it good on its own or does it need a block underneath it? 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #95776 2nd Dec 2011 5:48pm
33CHINACARS
Yes RR9701 something like that. Enough room around spare wheel to fit it in. Just hope never to use either.
Gary
Post #95840 3rd Dec 2011 4:30am
IIRC you need to put the car into "off road" setting so that the suspension travel is all but eliminated before the wheel leaves the ground when you start jacking..... Got - 2017 SDV8 Autobiography in Loire Blue
Post #95879 3rd Dec 2011 1:25pm
Forcing it into extended mode would be better but i don't think this can be done via internal buttons, just a testbook/faultmate?
Post #95883 3rd Dec 2011 2:01pm
funny enough i had to change a flat [salisbury plain Sad ] today and stuck it access and used the crappy range jack and tbh it went up quite easily..
Post #95929 3rd Dec 2011 8:09pm
Vogue
I've changed a full set of wheels using the std jack without issue, I also have 15 ton bottle jacks. Don't know what all the fuss is about with the std jack, it fits the locator under the cill and does the job. Yes a trolly jack would be quicker, but its not something you want to store in your boot, and is difficult to use on uneven ground.
Post #95942 3rd Dec 2011 8:44pm
its not the actual scissor jack its self, its the bar that turns the screw bit which ,in my case has bent ..maybe a more robust handle would make it easier to use..
Post #95962 3rd Dec 2011 10:08pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
you and your lad did a great job changing that tyre today Stan, must have been some sort of a record and with Disco3 lads looking on as well Thumbs Up FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #95969 3rd Dec 2011 10:19pm
thanks greg, it was the adrenalin pumping there and the fact we were holding you lot up....
Post #95973 3rd Dec 2011 10:30pm
GregP
I didnt feel like you were holding us up. I just felt bad it had happened to you as I was thinking as I drove up that a puncture would be a nightmare. You came prepared though which is prob why you sorted it so quickly. FFRR TD6 HSE
Post #95975 3rd Dec 2011 10:33pm
Post #95977 3rd Dec 2011 10:37pm
Page 2 of 3 <123>
